iron block indy 440-1 heads VALVE LASH SETTING???? #662901
04/06/10 08:16 PM
04/06/10 08:16 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
I have a World Products 4.500 siamese bore Iron block with Indy 440-1 heads CNC325cc.. the cam card (crane 688821) says .020 intake and .020 exhaust.. I understand that when the motor heats up, the aluminum expands at a different rate than the iron does... My question is,,, What do I set the valve lash at COLD considering the spec says .020 intake and .020 exhaust (HOT) Thanks for all your help.. nosboy
Re: iron block indy 440-1 heads VALVE LASH SETTING???? [Re: nosboy] #662902
04/06/10 08:51 PM
04/06/10 08:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would set mine .010 and .012 to acheve .020/.020
or go .012/.014 if it ends up .020 loose you will never know.
Re: iron block indy 440-1 heads VALVE LASH SETTING???? [Re: Dodgem] #662903
04/06/10 09:10 PM
04/06/10 09:10 PM
UK
602heavy Offline
602heavy  Offline
UK
Set them @ .014" cold , this should get you pretty close assuming RR is the same as spec card.
Re: iron block indy 440-1 heads VALVE LASH SETTING???? [Re: 602heavy] #662904
04/06/10 09:27 PM
04/06/10 09:27 PM
NC
440Jim Offline
440Jim  Offline
NC
Then check it hot once (quickly) and give yourself an actual number. I set my intakes tighter than that, but it isn't because of expansion, it just works with my combo.
Re: iron block indy 440-1 heads VALVE LASH SETTING???? [Re: 440Jim] #662905
04/06/10 10:49 PM
04/06/10 10:49 PM
gregsdart Offline
gregsdart  Offline
Like they said.
