She's dead after seven years of duty. #66261
05/30/08 03:43 PM
05/30/08 03:43 PM
Missouri
MY340 Offline OP
MY340  Offline OP
Missouri
My MP Orange Box ECU bit the dust but luckily right by the house on a quiet street as I was coming back from a short cruise.
Slapped on the old trusty spare Wells unit and she fired right up.
The black material on the MP box is soft and spongy. I think she was getting hot don't you?
Now I gotta throw on my spare TQ when time permits as I noticed a bad gas leak on the primary shaft passenger side. Old cars what fun!
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: She's dead after seven years of duty. [Re: MY340] #66262
05/30/08 04:00 PM
05/30/08 04:00 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Might be float level or leaky jet wells?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: She's dead after seven years of duty. [Re: Rug_Trucker] #66263
05/30/08 06:24 PM
05/30/08 06:24 PM
Missouri
MY340 Offline OP
MY340  Offline OP
Missouri
Yep tore it apart and the passenger jet well is leaking bad. The epoxy on them is original I'll go ahead and fix that problem as it's a good running TQ otherwise.
Rug,
What epoxy do you like to use? Some of the clear two part epoxies don't like gas I believe. I have a gray colored two part machineable epoxy that I think works better.
Re: She's dead after seven years of duty. [Re: MY340] #66264
05/31/08 10:07 AM
05/31/08 10:07 AM
Rug_Trucker Offline
Rug_Trucker  Offline
Rug,
I have used JB Weld or JB Quick.
Clean with alcohol and apply carefully with a tooth pick. If you get too much on the outside it won't fit into the carb base.
Machinable epoxy? What is that? Sounds like a neat thing.
Re: She's dead after seven years of duty. [Re: Rug_Trucker] #66265
05/31/08 10:09 AM
05/31/08 10:09 AM
Rug_Trucker Offline
Rug_Trucker  Offline
I scraped the old stuff off with a carpet knife (go figure!)
