Sending unit #662607
04/06/10 05:56 PM
04/06/10 05:56 PM
Fitchbug, Mass.
WannaRunner Offline OP
Fitchbug, Mass.
I just ordered a new Spectra gas tank through RockAuto. What sending unit do I order? the SPECTRA Fuel Sender with the 3/8" Outlet w/ Fuel Return? or the SPECTRA Fuel Sender with the 5/16" Outlet? this is for a vanilla '69 383 RR.
Re: Sending unit [Re: WannaRunner] #662608
04/06/10 06:38 PM
04/06/10 06:38 PM
Andrewh Offline
Andrewh  Offline
I would upgrade while I Was in there and cap the return, but stock was the 5/16th.
Re: Sending unit [Re: WannaRunner] #662609
04/06/10 08:10 PM
04/06/10 08:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Something wrong with your old fuel pickup/sender? I would upgrade to the 3/8 unit while you're there but it's not a necessity.
Re: Sending unit [Re: DaytonaTurbo] #662610
04/06/10 11:37 PM
04/06/10 11:37 PM
Fitchbug, Mass.
Fitchbug, Mass.
I got the 3/8, it is coming with the tank, thanks for the info. my current sender works when it feels like it, it is orignal. again thanks!
Re: Sending unit [Re: WannaRunner] #662611
04/06/10 11:44 PM
04/06/10 11:44 PM
Before you install it check the ohms at either end (of the travel) and also mock it up outside the tank, hot wire connected to it, jumper wire to a KNOWN good ground & (key on) see if moving the arm thru it's travel reads accordingly on the gas gauge as a helper checks it for you as there's been major issues w this (do a search). Better to confirm now then when in the tank full of gas.
