Re: Valve lash problems
[Re: CokeBottleKid]
#662208
04/06/10 11:43 PM
04/06/10 11:43 PM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
Everyone has a different opinion on this...
However...
FACT: adjacent rocker arms on the 'lobe' will cause shaft deflection.
I.E, if the intake valve is open and the exhaust is closed, the deflection will pull the exhaust arm away from the valve/lifter increasing lash.
Therefore: I always set my lash with BOTH valves closed at the same time.
I know that the valves appear closed or very close to closed when using the paperwork from Mopar that comes with their cams. TDC then rotating in 90* increments etc...
how acurate is the process on the mopar cams that use that procedure vs other methods?
This one
[Re: CokeBottleKid]
#662209
04/06/10 11:59 PM
04/06/10 11:59 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
However...
On the wedge cams the intake lobes, 1&2 are side by side, the exhaust lobes,#1&2 are on the other side of the intake lobes so when #1 int. is open # 2 ex. may or may not be affecting # 1 int and #2 int, same thing on # 2 int. and #1 ex BTW, when is the hazes coming out party?
