Page 3 of 6 < 1 2 3 4 5 6 >
#662052 - 05/25/11 11:08 PM Re: My Super Bee Project [Re: jpilone]
moparcyco Offline
Loc: southern Idaho
Got a little done today.Sanded,cleaned and painted my park lamp assemblies.Also installed my new lenses for them.Got theses from BE&A and they look and fit great.
lenses
assembled,not much but still progress
#662053 - 05/25/11 11:14 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Also finished the pedal assembly installed new bearings bushings and pads.Slowly getting there.
And ready to install,I can't wait to get to actually reassemble something for a change.
#662054 - 07/12/11 11:11 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Well not a lot of progress but while the suspension is out again I repainted everything.The first time I did it I knew nothing of paint or quality of paint so it got the krylon makeover not the most durable.So like a crazy person I redid it.The paint that is on there is custom mixed sherwin williams Industrial paint to be a pretty close match to Black phosphate.I think It turned out good much more durable as well.Hope to get the car off the rotisserie soon.
#662055 - 07/13/11 09:18 AM Re: My Super Bee Project [Re: moparcyco]
CDN72SE Offline
Loc: Oakville, Ontario, Canada
Nice job on the parts, they are looking good.
#662056 - 07/13/11 10:26 PM Re: My Super Bee Project [Re: CDN72SE]
moparcyco Offline
Loc: southern Idaho
Finally finished something for a change!Here are a few pics of the 8 3/4 rear for this car 3.23 sure grip new seals bearings all around.Ready to be installed for good this time I hope
Here is the housing
Installing third member
And done!
#662057 - 07/15/11 11:16 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Got the drivers side quarter on this one did not fit quite as well as the passenger side.Required a little finesse to get it on properly but not to bad.Almost to the really fun part blocking and filling and blocking and blocking did I mention blocking?My body guy has been great with letting me help and teaching me about body work.I am more in his way than helping but I'm learning and can say I helped
Edited by killerbee69 (07/16/11 04:22 PM)
#662058 - 07/16/11 12:12 PM Re: My Super Bee Project [Re: moparcyco]
70chall440 Offline
Loc: Washington State
Great project. that should be awesome when completed.
01 Viper GTS ACR 10 Challenger RT PCP 6spd 70 Challenger 440 6 pac 73 Cuda 416 Road Racer 70 Hemi Roadrunner 01 Ram 4x4 / 98 Ram 3500 91 Stealth RT 05 Durango Hemi 09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
#662059 - 07/18/11 11:31 PM Re: My Super Bee Project [Re: 70chall440]
moparcyco Offline
Loc: southern Idaho
Here is another small step.Finished the vent box.turned out nice,hit it with 0000 steel wool then washed real well used sem adhesion promoter and sem landau black.This stuff is great!It is very close to the original platic.Another good tip from here on moparts cleaned the metal part with a dremel and small wire wheel.Hit the whole thing with satin clear.Also had all the hardware done in silver cad.
sem products,I really like there products.
#662060 - 12/03/11 07:03 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Well more progress finally.Here are my us car tool subframe connectors almost fully welded in.I was hoping for a better fit,these took almost four hours a side to trim and gring to get to fit right.But overall they look awesome installed
#662061 - 12/03/11 07:16 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Here are the quarters on with welds ground and starting on the body work.
#662062 - 12/03/11 07:42 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Here ia the underside painted and coated with a sem bed liner undercoat product.Since the underside is now complete I installed the suspension permenantly.
#662063 - 12/03/11 07:46 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
here are the quarters a little more roughed in with another coat of primer and guide coat.
#662064 - 12/03/11 07:55 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
here are some more shots of the sem bed liner.Used ths all under the car and here where everyone will probably freak the interior floors,inside of the doors,inner fenders,trunk everywhere.This stuff is an awesome sound deadener and heat barrier.Took a ride in a car done this same way.The doors sound so solid when shut and is super quiet inside.
#662065 - 04/01/12 12:48 AM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Well finally doing some work again Instead of going with a lift off hood I decided to use a super clean flat hood I purchased from a fellow moparts member and make it look like a lift off style hood.I spent a week measuring and remeasuring,and another week getting the stones to actually start cutting.I decided to go this route instead of the fiberglass for two reasons the first is this will be a driver did not want to worry if it was windy and the hood needed to come off,the second was cost I am only in this setup $200 where as I would have been almost $700 for the fiberglass with shipping.Here are a few pics more to come soon.
#662066 - 04/03/12 06:59 PM Re: My Super Bee Project [Re: moparcyco]
Superfreak Offline
Loc: the great white north
How did you attach the scoop to the hood? Looks good.
"Too much to do and not enough time to do it"
#662067 - 04/03/12 11:50 PM Re: My Super Bee Project [Re: Superfreak]
moparcyco Offline
Loc: southern Idaho
Its 3m panel bonding adhesive.That is what my body guy suggested,I think it was a good call pretty easy to work with won't crack or ever come apart.
#662068 - 01/03/13 05:31 PM Re: My Super Bee Project [Re: moparcyco]
OhioMopar Offline
Loc: Mt.Gilead, Ohio
Any more progress on this build? Looking forward to the finished product!
Looking for my original 383 block. Last seen around the Atlanta area. 7449 are the last 4 of the VIN.
#662069 - 01/14/13 12:21 PM Re: My Super Bee Project [Re: OhioMopar]
moparcyco Offline
Loc: southern Idaho
Oh yeah its painted stay tuned for a whole buch of pics
#662070 - 01/14/13 12:35 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
Here are a few teaser pics that I took with my phone.Whole bunch more when I get everything uploaded and edited.
#662071 - 01/14/13 12:49 PM Re: My Super Bee Project [Re: moparcyco]
moparcyco Offline
Loc: southern Idaho
1 more sorry about the pic size I'm having a hell of a time learning photbuckets new edit crap
25,253 Registered Members
188,915 Topics
95RON as a standand octane at the pump?
by mopar dave
04/23/18 10:42 AM
For those who can't get enough ... new Ramcharger
by KISSAlien
04/23/18 10:21 AM
8 years under a cover "Forever Young" Diego is back!
by Diego_Ted
04/23/18 09:51 AM
Need help identifying Mopar performance part number
by WHITEDART
04/23/18 09:45 AM
