How much power will a 727 hold?? #661992
04/05/10 11:14 PM
04/05/10 11:14 PM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
What is the most power you guys have thrown at a 727?
I was going to convert to a glide for my new turbo big block set up but i wont have the extra funds this year for the glide and all the fab work ,driveshaft etc. I was hoping to turn the boost down a bit so i can race till fall.
www.sikosracing.net Heads up Drag racing
Re: How much power will a 727 hold?? [Re: moparmattkos] #661993
04/05/10 11:17 PM
04/05/10 11:17 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: How much power will a 727 hold?? [Re: WILD BILL] #661994
04/06/10 12:18 AM
04/06/10 12:18 AM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Re: How much power will a 727 hold?? [Re: moparmanjames] #661995
04/06/10 03:14 AM
04/06/10 03:14 AM
Netherlands
72Challenger Offline
Netherlands
My buddy has a cope and throws 1200hp to it @ 3700lbs without any problems.
Re: How much power will a 727 hold?? [Re: moparmattkos] #661996
04/06/10 11:39 AM
04/06/10 11:39 AM
Tucson AZ.
RADAMX Offline
RADAMX  Offline
Tucson AZ.
dynoed 1162 hp 1000ft torque
3345lbs.
aluminum front drum,roller rear drum,hypster brake,steel spined planetary,hughes converter.
love haveing the 3 speed trany as I run a lot of mph so I can't run a lot of gear in the rear
Re: How much power will a 727 hold?? [Re: moparmattkos] #661997
04/06/10 11:58 AM
04/06/10 11:58 AM
organ
maximum entropy Offline
Happy Birthday maximum entropy  Offline
organ
do you have stock shafts and planetaries? stock drum? if all those items (along with the usual billet servos and so on) have been replaced, it'll hold infinite power. i'd stick with the torqueflite. i love 'em.
Re: How much power will a 727 hold?? [Re: maximum entropy] #661998
04/06/10 06:11 PM
04/06/10 06:11 PM
Illinois
mopar addict
mopar addict
Illinois
It is stock shafts with aftermarketsteel drum, 4 gear planetarys, manual vb bolt in sprag and good clutches and steels. The car only weighs 2900
Re: How much power will a 727 hold?? [Re: moparmattkos] #661999
04/06/10 06:28 PM
04/06/10 06:28 PM
Stratford,Ct
7sec.cuda Offline
7sec.cuda  Offline
Stratford,Ct
we are throwing 1500hp at it at 3000#
Re: How much power will a 727 hold?? [Re: moparmattkos] #662000
04/07/10 11:42 PM
04/07/10 11:42 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
I would say safely 700. Remember the old Hemi SS cudas and darts basically had a similar tranny to what you have and made at least 500 hp stock then got beefed up and were probably pushing 700 back in the day when billet this and that wasn't available.
An aftermarket steel drum might be good but I like the aluminum ones better for that much power because of the RPM that thing sees(quite a bit more than the engine RPM by the way).
Re: How much power will a 727 hold?? [Re: 7sec.cuda] #662001
04/08/10 09:41 PM
04/08/10 09:41 PM
NC
440Jim Offline
440Jim  Offline
NC
7.51 at 182 mph, 1.10 sixty foot
You are the man!
