Re: Wiring up my transbrake
[Re: Otherlane]
#661573
04/05/10 12:45 PM
04/05/10 12:45 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
1 wire to a 12v source the other wire to the tranz brake wire
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Otherlane]
#661577
04/05/10 09:22 PM
04/05/10 09:22 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
12 volt power source thru trans brake button to one side of the solenoid and the other wire on the solenoid to ground is how I wire mine.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
[Re: Otherlane]
#661589
04/07/10 07:04 AM
04/07/10 07:04 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks moparfan,this what i was more looking for.On the back of my trans is a brass type fitting with a small nut.That should ground the transbrake out right? and where do i run that wire? to the button on my shifter right?
Look at that nut most likely that is where you hook the hot lead, the case of the solenoid should be grounded to the trans.... that nut should be isolated from the case
