stroker vs. aftermarket heads #661344
04/05/10 02:08 AM
04/05/10 02:08 AM
Texas, USA
68cuda2003 Offline OP
Texas, USA
OK guys. Need your input on making a decision. Got a '68 Barracuda with 12 point cage but it is going to primarily be a street car. Currently running a 440 with ported 906s with 2:19 intake valves, approximately 10.5:1 flat top TRW pistons at zero deck. My problem is I currently only have the $$ for either a 500" or a set of aftermarket heads. Which do you think would immediately improve my setup the most? Like everyone else, I just want to go as fast as possible!!! I am inclined to purchase the EZ-1s and build the stroker later to catch up to the heads. I have learned a lot form you guys over the years and really respect your opinions. Im certain I have left out some details, please ask. thanks, Ken
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661345
04/05/10 04:07 AM
04/05/10 04:07 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
Id go heads first, run the 440 for all its worth & build up another block on the side .
Re: stroker vs. aftermarket heads [Re: SG duster] #661346
04/05/10 06:54 AM
04/05/10 06:54 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: stroker vs. aftermarket heads [Re: SG duster] #661347
04/05/10 11:59 AM
04/05/10 11:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would do the block now and do the heads later. You will likely see more gain with doing the heads straight off but I see the heads as an easier bolt-on upgrade later down the road. With a stroker you will probably run out of breath at around 6k with the heads you have now.
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661348
04/05/10 01:09 PM
04/05/10 01:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stroker now and better heads later. I ran my 470 shortblock w/Ed Vickroy ported 906`s and went 10.40`s easy in my dart and as a daily driver to boot. Changing to rpm`s(which I now regret)netted me 10.0`s w/a 9.98 best with more left I`m sure.
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661349
04/05/10 01:13 PM
04/05/10 01:13 PM
Let see if I can help you on this descesion, I have several motors that have been ran in my 3400 lb street, pump gas Duster. The first motor was a 512 low deck with 906 heads like yours, 9.25 to 1 comp ratio, with a six pak intake set up,Comp Cams solid roller cam, it ran 10:69 at 123 MPH with the iron heads. I switch heads (same compression ratio, 84 CC heads on both)to a set of Eddy RPM CNC ported by MCH, the car ran 10:49 at 128.5 MPH. The second motor is 446 C.I. 440 block with the same 906 heads off of the stroker, 9.46 to compression, Eddy RPM Performer intake,Holley 950 HP carb. Comp Cams XE284HL cam. This motor ran 11:30 at 119 MPH. Either way will pick the car up, I would do the stroker kit, 4.25 stroke or larger Make it pump gas freindly, unless you have unlimited access to E85
Re: stroker vs. aftermarket heads [Re: Cab_Burge] #661350
04/05/10 04:19 PM
04/05/10 04:19 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd go heads, that's where the power will be. displacement will just give you what RPM the powerband will be, everything else being equal.
2017 Grand Cherokee Overland
Re: stroker vs. aftermarket heads [Re: patrick] #661351
04/05/10 04:31 PM
04/05/10 04:31 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
I would go with the heads also!
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661352
04/05/10 04:56 PM
04/05/10 04:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My opinion is to do the stroker kit now, put the engine
in then later all you need to do is through the heads
at it... no more pulling the engine
Re: stroker vs. aftermarket heads [Re: MR_P_BODY] #661353
04/05/10 05:10 PM
04/05/10 05:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Humm.. I would wait and save your bux up and build a proper stroker cubes and heads Sorry I know this didn't help much
Re: stroker vs. aftermarket heads [Re: MR_P_BODY] #661354
04/05/10 05:12 PM
04/05/10 05:12 PM
tboomer Offline
tboomer  Offline
That is what I would do...
Re: stroker vs. aftermarket heads [Re: tboomer] #661355
04/05/10 05:37 PM
04/05/10 05:37 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Lot of people would be disappointed in thinking the 440 vs 500 is big gains given the same other parts and topend. The 3.75 stroke will get it done with the correct heads. Stock heads ported heads even pro done will usually make a great tow motor with a long arm....
In a nut shell you would be narrowing the power band, which IMO is counter productive in a racey type build.
Fact is the two same engines will have similar power outputs given the same parts in this type motor.
Well the stroker might make a little more mid range, but suffer from topend Asama for breathing with stock heads.
Re: stroker vs. aftermarket heads [Re: Bob_Coomer] #661356
04/05/10 05:49 PM
04/05/10 05:49 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
also, Look at the power Wild Bill is making (700+) with a 440, smallish solid cam, and Eddy heads! get the heads first!
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661357
04/05/10 06:01 PM
04/05/10 06:01 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
How fast is it now? What shape is the short block in? Would better heads simply light the fuse faster on a time-bomb bottom end?
Re: stroker vs. aftermarket heads [Re: BradH] #661358
04/05/10 06:48 PM
04/05/10 06:48 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
From your original post I gather you have stock rods and stock crank. I would make sure I had the bottom end built to handle the rpm your gonna turn with the better breathing heads or it could get real expensive especially if you step up on cam to take advantage of the better flowing heads.
Good luck!
Re: stroker vs. aftermarket heads [Re: challenger73400] #661359
04/05/10 07:22 PM
04/05/10 07:22 PM
gregsdart Offline
gregsdart  Offline
Good luck!
I agree. You want to build a solid foundation first, leave the heads till later due to them being crack prone. If that happens, you aren't out much. If you go heads first, your choice of gears and converter will probably be different. So you save there. Basically, the low end torque of the stroker will be close between the iron heads and the aluminum heads. The shift point will rise and the hp will go up. Also, you will have an animal on the street with the extra cubes, even with iron heads.
In the end, stroker Vs stock the stroker will be faster with either heads.
Re: stroker vs. aftermarket heads [Re: gregsdart] #661360
04/05/10 07:52 PM
04/05/10 07:52 PM
Texas, USA
Texas, USA
Yes, the bottom end is OK. The rods are stock but polished beams and good bolts. Steel crank. One of the main reasons I wanted to do the bottom end first was the heavy TRW 6-pack pistons. Also, its going to take several hundred dollars to put the engine back together so I would just apply it to the cost of the new addition. I also figured that going from around 90 cc open chamber heads to 75 cc heads would increase compression. Add that to improved flow and to me its a win win situation. As you can tell, IM still undecided. You all make good points, any other opinions out there?? As you can tell, the poll has not been too one sided.
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661361
04/05/10 07:59 PM
04/05/10 07:59 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
you might want to cover the rest of the combo.
If you have a 440 A body cuda that's mostly on the street and want to go faster, what kind of tire do you have and how well does it hook now?
trans, converter, weight, other mods?
Re: stroker vs. aftermarket heads [Re: RodStRace] #661362
04/05/10 08:15 PM
04/05/10 08:15 PM
Texas, USA
Texas, USA
well, the car has been under construction for 23, yes 23 years!!! It will have the largest mickey thompson pros or 15X33s for the strip, with a 12 point cage. the converter is a 9" but it needs to be redone anyway. I was told it weighed 2800 with a hemi and a dana and I have replaced it with a 440 and a 9" so Im guessing around 2700. Thanks for everyones input thus far.
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661363
04/05/10 08:28 PM
04/05/10 08:28 PM
Lehigh Acres, Florida
rickstershemi Offline
I would go with the heads 1st and work on putting a separate stroker short-block together while your enjoying the car
Rickster
