727 parking pawls-levers #660601
04/04/10 01:34 PM
04/04/10 01:34 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
Did they do any year change on the pawl-lever-tailshaft ? Can't get my shifter adjusted to this trans to go all the way in to park. never have any trouble with this before. My trans that blew up end of last year and for 3 years before work fine. Borrowed a trans at the end of last year. Never had to ajust anything work great. Now with this trans don't want to go all the way in to park It is close you can hear the pawl ratching-clicking almost going in. Same shifter-cable-valve body. only thing change here is main case-tall shaft housing. has same outputshaft and parking gear. I have ajusted it 6-7 times over the last two days. will start in park and neutal. any ideas..I am about to put my other tailshaft housing back on it ?
Re: 727 parking pawls-levers [Re: VernMotor] #660602
04/04/10 02:58 PM
04/04/10 02:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're using the same VB I will assume that you're using the same park rod that worked in other transmissions, the 904 and 727 park rods are different
With the VB removed, look into the hole that the park rod passes through and note the position of the snap ring that holds the tapered ramp into the tailhousing; in rare cases the position of the snap ring ears will interfere with the park rod operation. If the bottom ear is installed low in the housing the park rod can get wedged against the pawl.
Re: 727 parking pawls-levers [Re: John_Kunkel] #660603
04/04/10 03:03 PM
04/04/10 03:03 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Same park rod..Ok I will look the snap ring..Good info thank you.
Re: 727 parking pawls-levers [Re: VernMotor] #660604
04/05/10 07:00 PM
04/05/10 07:00 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Well here is pics of both parlking pawls.. something a little diff about them.
Re: 727 parking pawls-levers [Re: VernMotor] #660605
04/05/10 07:13 PM
04/05/10 07:13 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Which one are you having trouble with?
Re: 727 parking pawls-levers [Re: WILD BILL] #660606
04/05/10 07:27 PM
04/05/10 07:27 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
The one that has fluid in it. Is the trouble maker ! I just try the old one and it works fine ! that what I get for trying a new one Just because LOL.. the new one came off a late model lock up small block 727..got me ?? Maybe they ain't all the same ?
Re: 727 parking pawls-levers [Re: VernMotor] #660607
04/05/10 07:45 PM
04/05/10 07:45 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Kinda looks like the cut out on the lower one is smaller then the upper
Re: 727 parking pawls-levers [Re: VernMotor] #660608
04/06/10 05:27 PM
04/06/10 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The snap ring in the upper pic is clocked in the preferred position, in the lower pic the ear of the snap ring is low enough to allow the rod to become positioned under the sprag and over the ear of the snap ring.
Re: 727 parking pawls-levers [Re: John_Kunkel] #660609
04/06/10 05:41 PM
04/06/10 05:41 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
OK I see what you are saying John..You bet I be looking for that from now on !! Thank you
Re: 727 parking pawls-levers [Re: John_Kunkel] #660610
05/30/10 11:33 PM
05/30/10 11:33 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
wonder if this is my issue ... it looks like this
Mopar Performance
