Which Trans to Use? #66017
05/30/08 12:34 AM
05/30/08 12:34 AM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
I am building a mild 340 for a 73 RR, street only with 323 or 355 gears. Should I try to find a 727A or just use the 904 I have laying here? Which trans would have likely come in this car? 904 or 727. It is an orig 340 auto car. Data tag is too rusted to read. I have a 904 and am looking for a 727A without luck so far.
Some people you just can't reach...
Re: Which Trans to Use? [Re: Suregrip] #66018
05/30/08 09:57 AM
05/30/08 09:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
727 should be easy to find , how many do you need ?
the 904 will work , if you beat it you might want to find or modify your to A998 , 5 clutch drums , status .
you car would originally have had a 727 .
PM me your zip code , my brother runs up and down the east coast , i have a 727A that i'm tripping over , it was a good working trans when i pulled it from the car i parted .
Re: Which Trans to Use? [Re: JohnRR] #66019
05/30/08 09:42 PM
05/30/08 09:42 PM
Fort Lauderdale, FL
Suregrip Offline OP
Suregrip  Offline OP
Fort Lauderdale, FL
Thanks John RR, but I think I might have found a 727A today. I will let you know if it doesn't work out and maybe I can still get yours. Thanks, Fred.
Re: Which Trans to Use? [Re: Suregrip] #66020
05/31/08 01:56 AM
05/31/08 01:56 AM
904.(1)lighter(static & rotating)(2) more clearance.they do need more beefing.One guy was in the 10's with a SB/904/66val with not that much trick stuff in it.
