Re: 727 OIL LOSS PLEASE HELP!
[Re: blown360]
#659894
04/03/10 01:51 PM
04/03/10 01:51 PM
[Re: blown360]
#659896
04/03/10 02:02 PM
04/03/10 02:02 PM
Weve drained the box so am I right in saying we should refill by 6.5 quartz to alloiw for the leftover oil in the verter? Does that sound about right?
your going to have fluid in the converter as well as the lines so no more than 6 quarts.
[Re: blown360]
#659898
04/03/10 02:08 PM
04/03/10 02:08 PM
Are all the deep alloy sumps the vsame cxapacity? this one measures approx 3.5" deep.
no, there are different size ones. put in 6 quarts, start it up get it warm in nuetral, pull out dipstick and it should read add 1 pint.
[Re: blown360]
#659904
04/03/10 05:05 PM
04/03/10 05:05 PM
goodluck to you guys over there!
[Re: blown360]
#659905
04/03/10 05:32 PM
04/03/10 05:32 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The FULL mark on the dipstick is 1/4" (6.3MM) above the ledge on the case that the tube inserts into.
[Re: John_Kunkel]
#659907
04/04/10 09:43 AM
04/04/10 09:43 AM
Posts: 16,923 NC
440Jim
NC
John, Are you referring to the top ledge shown in my attached picture (1-1/4 from pan gasket surface)?
I don't have a dipstick and tube except those installed in my cars to check.
[Re: moparmxz]
#659910
04/04/10 12:36 PM
04/04/10 12:36 PM
Posts: 1,880 USA
Ron Silva
USA
Just for reference, here is a setup I have here and I believe it is for a 904. I have several tubes and dip sticks and this shows it would in fact be above the boss the tube goes into. All my setups total variance is about 1/4" max mixing and matching tubes and sticks.
727 is probably similar if not the same. So 1/4" above the boss is most likely correct.
SRT DEMON ONE SEAT
[Re: moparmxz]
#659913
04/04/10 03:06 PM
04/04/10 03:06 PM
I,ve experienced the same thing, the level needs to be full or my trans shifts funky.I always just assumed when in use the level goes down from fluid pumping fast and not returning to the pan fast enough.
i have had same situation also.UNDERFILL AT CECIL COUNTY LOST .2 AND 3 MPH, ADDED A QUART AND ran my best ever.you can feel the trans. not pulling right. like a drag.but if you overfill by a 1/2 quart it pukes out the front pump vent hole. this front pump hole needs to be plugged and a top vent needs to be put in on next rebuild.
[Re: Ron Silva]
#659915
04/06/10 03:51 PM
04/06/10 03:51 PM
Posts: 16,923 NC
440Jim
NC
That and John's words say it all, and explain my experience. I guess that super deep pan and filter extension really only adds fluid capacity (cooling?) and the same pan with a 1" extension would get basically the same benefit, since the level needs to be so high (above the valve body).
And that debunks some other posts in the past that say it is OK to run a torqueflite low on fluid. The exact mark may be debateable, but I believe in the concept; for a race trans anyway.
[Re: 440Jim]
#659916
04/06/10 05:07 PM
04/06/10 05:07 PM
Posts: 1,880 USA
Ron Silva
USA
I just talked to Dave from Pro Trans and he said that the level can NOT be run low, like 1" or near the pan rail. He said you cold run it a little low, like 1/4" just to be safe if you have a habbit of puking oil out the vents, but it needs to be near a stock/normal level. It cannot be run low despite having the deep pan and filter extension.
SRT DEMON ONE SEAT
