A 12 guys, how do these wires look ?? #65972
05/29/08 11:03 PM
05/29/08 11:03 PM
Cleveland
sunroofgtx Offline OP
Cleveland
Not going for number's matching, just how the wires are routed. Take note of the use of 90's and 180's at the distributor cap. Can the coil wire be 90 degrees and work ok ? How about # 7, 90 or 180 ? Thanks a ton. We are making a lot of these sets, and no complaints yet.. Can't be perfect, just want to look semi-correct.. Thank you..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: A 12 guys, how do these wires look ?? [Re: sunroofgtx] #65973
05/30/08 10:13 AM
05/30/08 10:13 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
These wires are great! You need to pop the tags off after you install them to make them look more correct.
Re: A 12 guys, how do these wires look ?? [Re: THESHAKERPROJECT] #65974
05/30/08 11:19 AM
05/30/08 11:19 AM
Cleveland
Cleveland
My only thoughts are that pre 1970, all of the distributor boots are 180's, except for number 8.(we think) We are not trying to be concourse, just give customers something that looks mostly correct but performs better than anything else available..Thanks for the feedback. We send them with the markers so customers know which lead goes where.. Thanks, Rick G
Re: A 12 guys, how do these wires look ?? [Re: sunroofgtx] #65975
05/30/08 01:32 PM
05/30/08 01:32 PM
The Last Frontier
Alaska_A12 Offline
Alaska_A12  Offline
The Last Frontier
You might do better asking the question here !
______________________________________________ http://regcars.homestead.com/car107.html
Re: A 12 guys, how do these wires look ?? [Re: sunroofgtx] #65976
05/30/08 09:02 PM
05/30/08 09:02 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
This may help
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: A 12 guys, how do these wires look ?? [Re: Kowal] #65977
06/02/08 06:03 PM
06/02/08 06:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What's the source of that picture of the original wires?
Re: A 12 guys, how do these wires look ?? [Re: BradH] #65978
06/02/08 07:06 PM
06/02/08 07:06 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
David Wise at the ICCA...lot's of reference pics on the website.
http://www.iccahome.org/
Re: A 12 guys, how do these wires look ?? [Re: Kowal] #65979
06/03/08 12:07 AM
06/03/08 12:07 AM
Cleveland
Cleveland
This may help
Thanks, so 2 is a 90 also ?!?!. We knew 1-3-5-7-8 were 90's. What year did this configuration start ? 69 1/2 ? Nice info..TY
Re: A 12 guys, how do these wires look ?? [Re: Kowal] #65980
06/03/08 10:18 PM
06/03/08 10:18 PM
BradH Offline
BradH  Offline
Sorry, no time to check out that link. However, I believe the Moparts member SUPERSTOCKRACER is the current owner of one of the lowest mileage original A12 Road Runners and I'm sure whatever his plug wire setup is could be considered correct, too. I have an old Mopar Action that has pictures of his car & engine compartment, but it's filed away somewhere and not readily accessible to see what those pictures show.
Re: A 12 guys, how do these wires look ?? [Re: BradH] #65981
06/04/08 05:16 AM
06/04/08 05:16 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
What ever you think is right. David Wise runs what I think is the country's best recognized judging outfit for concourse judging of Mopar's at National events...published several guides on what to look for.
Re: A 12 guys, how do these wires look ?? [Re: sunroofgtx] #65982
06/04/08 08:27 AM
06/04/08 08:27 AM
sixbbl69 Offline
sixbbl69  Offline
i have been running the same date coded wires for 20 yrs with no problems. wouldn't mind replacing them with an upgraded set. what is so hard about making some with date codes?i guess i will wait until someone can reproduce something with the better wire that looks original.if i have to spend the money it may as well be right.
Re: A 12 guys, how do these wires look ?? [Re: sixbbl69] #65983
06/04/08 12:25 PM
06/04/08 12:25 PM
Cleveland
Cleveland
I agree. Someone had those date coded wires on their fresh engine, and it backfired all the way down the track. He switched to ours and I think he made a Chrysler division stamp for the yellow lettering.
