REAR MAIN SEAL #65497
05/28/08 11:45 PM
05/28/08 11:45 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
okay, here is my problem, i have 440, 1973 motor home 440, i bought the engine from a friend, the engine has not been rebuilt, however some new things have been added, on the rear main seal, the top seal is still the old rope seal and the bottom is the new neroperne seal, it leak when i cranked up the car, the motor is still in the car, i have the oil pan off, i have the real main seal retainer cap off, the problem i have, i have gotten most of the old rope seal pushed out of the top, however there are some pieces stuck in the slot where i need to slide the new seal into place, is there any tricks in getting all the old seal out of slot, i have pushed wire rods up and and over, however i have been unsuccessful in getting all the seal out, i have went and bought some small parts bushes to stick in the slot, is there something i can spray in the slot to disolve the old seal?
Re: REAR MAIN SEAL [Re: cornet684me] #65498
05/29/08 12:50 AM
05/29/08 12:50 AM
keep workin' it till it comes out. otherwise you know what you'll have to do if that dosn't fan out.
Re: REAR MAIN SEAL #65499
05/29/08 11:29 PM
05/29/08 11:29 PM
Brandon, Ms
Brandon, Ms
you mean pull the engine ? please say no
Re: REAR MAIN SEAL [Re: cornet684me] #65500
06/02/08 07:28 PM
06/02/08 07:28 PM
Brandon, Ms
Brandon, Ms
good news, i got a new rope seal into the block and new nerophrene bottom seal, i have not crank car up yet, i have my fingers crossed
Re: REAR MAIN SEAL [Re: cornet684me] #65501
06/02/08 07:41 PM
06/02/08 07:41 PM
I suggest that you use rope on the bottom half also.
Re: REAR MAIN SEAL [Re: RapidRobert] #65502
06/02/08 08:07 PM
06/02/08 08:07 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Hopefully you didn't destroy the seal surface on the crank trying to get the old rope seal out of there.
Re: REAR MAIN SEAL [Re: HPMike] #65503
06/02/08 11:14 PM
06/02/08 11:14 PM
Brandon, Ms
Brandon, Ms
i just cranked the car ran for about 10mins no leaks so far, do you think it worked?
Re: REAR MAIN SEAL [Re: HPMike] #65504
06/02/08 11:16 PM
06/02/08 11:16 PM
Brandon, Ms
Brandon, Ms
i checked the crankshaft in detail, i did not scratch the crank shaft, i kept the crank shaft in check and spun it around and did not work on just one side, i think i have done it
Re: REAR MAIN SEAL [Re: RapidRobert] #65505
06/02/08 11:18 PM
06/02/08 11:18 PM
Brandon, Ms
Brandon, Ms
i used the nerophrene on the bottom and put a little rtv on the retain cap side
Re: REAR MAIN SEAL [Re: cornet684me] #65506
06/03/08 12:11 AM
06/03/08 12:11 AM
keep those fingers crossed
Re: REAR MAIN SEAL [Re: RapidRobert] #65507
06/05/08 11:03 PM
06/05/08 11:03 PM
Brandon, Ms
Brandon, Ms
i have run the engine around 10mins, no oil leak
