Sealed Power/Federal Mogul 1006R camshaft, specs? #65460
05/28/08 10:26 PM
05/28/08 10:26 PM
MN
mkvien Offline OP
mkvien  Offline OP
MN
Does anyone have a catalog with any specifications for this camshaft? It should be for a small block. On the end of the cam is says "1006R" and a "G" by itself. I am guessing it is a Federal Mogul or Sealed Power, as a web search turned up that number in one of their catalogs, but all it lists is "performance" for specs.
Thanks in advance, trying to figure out if this will work for my application.
Re: Sealed Power/Federal Mogul 1006R camshaft, specs? [Re: mkvien] #65461
05/29/08 10:46 AM
05/29/08 10:46 AM
Utah
O
orangemonster Offline
super gas
super gas
O
Utah
pro-2000 smooth idle 1500-4000 rpm dur@ .o5o 204/204 valve lift .420/.420 lobe c/l110 overlap 50.
Re: Sealed Power/Federal Mogul 1006R camshaft, specs? [Re: orangemonster] #65462
05/29/08 06:49 PM
05/29/08 06:49 PM
MN
mkvien Offline OP
mkvien  Offline OP
MN
So a very tame camshaft, looks very comparable to at Comp 252H. Should be a little more perf than the stock one.
Comp 252H
Dur @.050 = 206
Lift = .425
lobe/sep angle = 110°
