Carter AVS & fuel pressure #65443
05/28/08 10:22 PM
05/28/08 10:22 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
The stock LA fuel pump is not keeping up with my 360 above 4000 rpm or so at WOT. I have purchased a Carter 6 psi "street" mechanical fuel pump as a replacement. Will my AVS be okay with 6 psi, or am I going to need to plan on pressure regulation??
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Carter AVS & fuel pressure [Re: GO_Fish] #65444
05/28/08 10:28 PM
05/28/08 10:28 PM
Should be fine. My old '70 manual shows as high as 7-8 1/2 lbs for hemi pumps
Re: Carter AVS & fuel pressure #65445
05/29/08 08:39 AM
05/29/08 08:39 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
6 psi will work fine. Make sure the pick up filter in the tank is not clogged.
Re: Carter AVS & fuel pressure [Re: 69Cuda340S] #65446
05/29/08 09:17 PM
05/29/08 09:17 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Cool, one less thing to worry about. I had not considered the tank issue, and I have not been in there yet, so if the pump doesn't fix it, that may be something to consider.
Re: Carter AVS & fuel pressure [Re: GO_Fish] #65447
05/29/08 09:36 PM
05/29/08 09:36 PM
I would suggest hooking up a T & a gauge & see what psi you DO have with the stock pump after you hit 4000 rpm & yes check the sock.
