If you do go s/c, make sure you buy a unit upfront that's going to flow enough to support your goals. I bought mine for a decent price, but if I had to do it all over again I would spend the extra $ on a unit with a higher flow. You would rather have a unit with some capacity to spare than one you have to push to the limit.
That is one of my biggest concerns with a S/C. Getting one that won't flow enough. I'm not planning on a ton of boost from the start, but I don't want to end up with the S/C running maxed out from the start and only making 6lbs either. I'd like some room to play with it.
