Re: 413 motorhome engine ???"s
#651571
09/13/10 01:53 PM
09/13/10 01:53 PM
Posts: 30,250 Florida STAYcation
dIc dOc Deity !
The village idiot's idiot
Florida STAYcation
much easier just to take a felt marker and write "413" on the 383's valvecovers... no?
WH .....???? ... whatchoobeensmokin?
[Re: partfiler69]
#651572
09/13/10 01:56 PM
09/13/10 01:56 PM
dIc dOc Deity !
Florida STAYcation
Ok, thanks for the tip. What would be a better head to use instead of the 906's. What if I had the 906's flat milled .040?
What do you plan on doing with the engine combo ? ... have you pulled the heads off that 413 ? ..... the 906's can not be milled enough to get decent compression with that shortblock.
[Re: partfiler69]
#651578
09/13/10 03:21 PM
09/13/10 03:21 PM
Posts: 28,063 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Be sure to cut the intake side of the heads to keep the geometry the same. You can't slam .060" off the intake ports. It requires a different amount and possibly a different angle to keep things the same.
[Re: feets]
#651579
09/13/10 09:12 PM
09/13/10 09:12 PM
Posts: 223 Poplar Bluff, Missouri
partfiler69
Still Wondering
Still Wondering
Well, from what I am reading about the low compression of this beast, it seems to have BOOST written all over it!
Back from hiatus
[Re: partfiler69]
#651585
09/14/10 07:28 PM
09/14/10 07:28 PM
dIc dOc Deity !
Florida STAYcation
383 pistons will work ... but you will have about 4 to ONE compression ratio ..
Can't I just have the heads flat milled .010?
MORE LIKE .....1.100 !!
[Re: partfiler69]
#651588
09/15/10 04:01 PM
09/15/10 04:01 PM
I think someone did some measuring and figured out that 383 pistons would work in a 413 (bored to 4.25) with a 4.15 stroker crank. Not sure anyone has ever actually tried it, though.
That would make it a 472, BTW.
#651589
09/15/10 04:35 PM
09/15/10 04:35 PM
Posts: 15,487 Florida
scratchnfotraction
a 440 crank in a 400 block makes a 470 stroker would be sweet to make a 413/472 strokers as well I think I will swing by and pick up that MH 413 thats for sale in my town I think the odd looking wp and tall heads would deff be kool looking in my 85 truck should be fine for towing my 440 truck around instead of the 318 sb thats in it is 300$ a bad deal?,it runs and moves the MH down the road good,no smoke,noise..ect.. its just a PITA to pull out,hope they want to scrap it so I can
