AMD sheetmetal parts review
#65036
05/28/08 10:28 AM
05/28/08 10:28 AM
Just received a rear deck filler panel and rear window repair panels from AMD.Heavy guage metal.Good thick steel-but the stamping leaves something to be desired.The panel has ripples alomg the two ends where it meets the 1/4 panels,and all the edges look too "soft".The trunk gutter stampings all look rounded instead of crisp bends too. The window patch panels are just that-patch panels.wavy,and made to bridge right over the deck filler panel instead of a proper flange. Have to say I was expecting nicer quality from AMD,especially considering these parts are available from other companies too.I was hoping they would make the top quality stuff that others don't. I have not fit the deck panel yet,so it might work just fine,but the wavy ends mean some work will be needed.
Re: AMD sheetmetal parts review
[Re: buzz440]
#65039
06/05/08 09:33 PM
06/05/08 09:33 PM
Posts: 169 Maine
itali83
Maine
Glad I didn't spend the extra money to buy my 1/4's and deck filler panel from them. I wen tthrough parts unlimited llc and hopefully they turn out ok, I'll be getting them next week so we'll see.
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
[Re: Rhinodart]
#65043
06/07/08 09:22 AM
06/07/08 09:22 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
I am assuming 70 B-Body? I haven't seen this problem with other parts from them, please make sure you tell us EXACTLY what year and car you are using them for!
i don't think a 70 is available yet and if it is he got TEST pieces and SHOULD be telling AMD about it not like a little girl on the internet
[Re: JohnRR]
#65044
06/07/08 10:47 AM
06/07/08 10:47 AM
The panels are for a 68-70 B body.Going on a 70 Coronet.The flaws are obvious,so they know.Once again JohnRR you find a way to turn all this negative.I was simply sharing info about new parts available.Yes,AMD has been informed.I still look forward to their new parts and I am not knocking the company or their efforts to produce parts we all need.
#65045
06/07/08 11:02 AM
06/07/08 11:02 AM
JohnRR
U.S.S.A.
anything to give you a helping hand
sorry , but your original post stinks of knocking AMD , you gave little to any info till i SUPPOSEDLY turned this negative ...
