Mopar Perf Elec Distributor Advancing #64990
05/28/08 08:49 AM
05/28/08 08:49 AM
Lexington,VA
68gtxsurvivor Offline OP
Lexington,VA
I installed a mopar performance distributor and the vacume advance is pulling 60 degrees when plugged up. Whats awrong with it? thanks for any help
Re: Mopar Perf Elec Distributor Advancing [Re: 68gtxsurvivor] #64991
05/28/08 10:50 AM
05/28/08 10:50 AM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
sounds like its working fine to me. Timing is checked with the vacuum hose taken off of the dist and plugged. Should read 36-38 degrees at 2500rpm or so.
