68 Charger metal grill frame color #64853
05/27/08 10:06 PM
05/27/08 10:06 PM
At a gas station near you
badblack68 Offline OP
What is the correct color for the grill frame for a 1968 Charger? The color of the car is black. Someone told me gloss black, others have told me satin black, and other have told me the top plate would be gloss black and the rest of it semi-gloss black. I`m confused, what is the correct color to use?
Re: 68 Charger metal grill frame color [Re: badblack68] #64854
05/27/08 10:40 PM
05/27/08 10:40 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you mean the upper panel that's visible when you open the hood, my original '68 & '69 Chargers were about a 30% flattened black - slightly shinier than a semi-gloss, but no way a shiny black like what the exterior panels would be on a black car. Not a rich shade of black either, but more like what you see on dipped parts. I wouldn't try to duplicate it with a rattle-can though, the area's too big.
Re: 68 Charger metal grill frame color [Re: badblack68] #64855
05/28/08 07:36 AM
05/28/08 07:36 AM
Toronto, ON
Shakey Offline
Shakey  Offline
Toronto, ON
I used Eastwood's Under Hood black.
1969 Dodge Charger R/T SE - 440 AUTO
Re: 68 Charger metal grill frame color [Re: topside] #64856
05/28/08 12:39 PM
05/28/08 12:39 PM
Thanks, I`m definately not using a rattle can on this part. It will be painted using a spray gun once it`s been blasted clean. There`s some of the cars original light green color on some parts of this assembly.
Re: 68 Charger metal grill frame color [Re: badblack68] #64857
05/29/08 06:52 AM
05/29/08 06:52 AM
Toronto, ON
Shakey Offline
Shakey  Offline
Toronto, ON
Under Hood Black is also available in quarts for your gun.
Re: 68 Charger metal grill frame color [Re: badblack68] #64858
05/31/08 10:02 AM
05/31/08 10:02 AM
These parts were not sprayed when new,they were dipped in a tank of paint.
If you really want it correct looking,hang it by one end and spray it with over reduced paint and get it running.Correct yes-sloppy yes.Of course everyone will think you are a hack-but it would be more correct that most of the OEM Gold over-restored trailer queen's grille panels
Re: 68 Charger metal grill frame color [Re: badblack68] #64859
05/31/08 02:38 PM
05/31/08 02:38 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
This panel? If so it was gloss black.
Amazing how an unchallenged lie can become the absolute truth.
Re: 68 Charger metal grill frame color [Re: beepbeep] #64860
06/03/08 12:16 AM
06/03/08 12:16 AM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Killerbee70
You are absolutely correct-I have a lot of pictures of originals and they have huge runs in them!
Re: 68 Charger metal grill frame color [Re: Paul Jacobs] #64861
06/03/08 11:11 PM
06/03/08 11:11 PM
My grill support still has the factory runs on it. I`m not going to try and duplicate it. It was never originally gloss black. It looks like it was a shade between gloss black and semi-gloss black. Thanks for the help
Re: 68 Charger metal grill frame color [Re: badblack68] #64862
06/03/08 11:37 PM
06/03/08 11:37 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
It was gloss black, just not polished the way the body was.
Re: 68 Charger metal grill frame color [Re: beepbeep] #64863
06/04/08 01:30 PM
06/04/08 01:30 PM
Well I guess after 40 years the gloss of the black has turned to a semi-gloss color. Thanks again for all the help with this issue.
