Wilwood Residual Valve Question #64735
05/27/08 06:14 PM
05/27/08 06:14 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Okay, these are going into the Demon:
Wilwood tandem plastic resevoir master cylinder (2 outlets, one front circuit, one rear circuit)
Wilwood 10lb residual valve (discs in the edit: front, drums in the back)
Wilwood adjustable proportioning valve
My question lies with the residual valve. The instructions say to "install after the tee fitting," but is that if you have a single outlet master cylinder, or do I still need to install it behind the distribution block in the middle of the lines?
This site (http://www.foundationpc.com/stories/brakes.html) says that the "junction box" (tee fitting?) doesn't connect the lines. Does the residual valve have to go behind it, or can it just be run like this:
(purple ends toward brakes)
Re: Wilwood Residual Valve Question [Re: sharpie] #64736
05/27/08 06:20 PM
05/27/08 06:20 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Sorry misread your post that is correct.
Boy I need to get some lunch... I thought the residual was in front of the 't' which is correct but looking at it now, I think the residual should be after the prop valve but before the 'T' in the rear
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Wilwood Residual Valve Question [Re: HealthServices] #64737
05/27/08 06:29 PM
05/27/08 06:29 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
sorry, I thought I wrote it, drum in the rear.
Re: Wilwood Residual Valve Question [Re: sharpie] #64738
05/27/08 08:22 PM
05/27/08 08:22 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
any other ideas? Drum in the back, disc in the front.
Re: Wilwood Residual Valve Question [Re: sharpie] #64739
05/28/08 03:53 PM
05/28/08 03:53 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
bump
Re: Wilwood Residual Valve Question [Re: sharpie] #64740
05/28/08 08:05 PM
05/28/08 08:05 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
they can go before the block,no problem.
logically there is no reason why not,other than the single res. master you mentioned
Re: Wilwood Residual Valve Question [Re: west] #64741
05/30/08 04:44 PM
05/30/08 04:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree before the block will be fine. The factory setup has them in the Master Cyl which would be basically the same. Ron
