Re: Are there any members here that sell ROL gaskets?
[Re: ProSport]
#647209
04/08/10 11:26 PM
04/08/10 11:26 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Corteco..which is now ROL!! And they are not white anymore,they are a light blue color.
So are these Edelbrock Corteco's any good? Seem awful cheap in price.
I thought so too, and they are available. I bought a set a while back, but haven't run that engine .....yet. Mark
[Re: Hemi Allstate]
#647210
04/09/10 07:00 PM
04/09/10 07:00 PM
Posts: 17,916 Akron, Ohio
ProSport
Akron, Ohio
I think I'm gonna try these Edelbrock/ROL gaskets, or at least go look at them at Summit this weekend.
[Re: ProSport]
#647214
04/14/10 10:16 PM
04/14/10 10:16 PM
ProSport
Akron, Ohio
Ok, I finally had a few minutes to run in Summit and check out the Edelbrock/ROL #7325 head gaskets. 4.45 bore, .038 thick, steel core laminate, and they are white in color. The guy at Summit said they look like good quality and that construction should be good for 12 to 1 plus. I would have bought them if I hadn't already special ordered some new copper gaskets.
[Re: ProSport]
#647216
04/15/10 02:19 PM
04/15/10 02:19 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
The guy at Summit told me they were now light blue.Guess he didn't look at them like he said he did.
[Re: Chris2581]
#647217
04/15/10 02:47 PM
04/15/10 02:47 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
There have been/is a mix of blue and white gaskets. For a while, you didnt know which ones you may get.
RIP Monte Smith
[Re: CompWedgeEngines]
#647218
04/21/10 04:12 PM
04/21/10 04:12 PM
Chris2581
Jacksonville, FL
Well,we still don't know!! I ordered a set of Edelbrock gaskets and they are Fel-Pro 8519PT-1's.For $53.00 they will go back to Summit.
[Re: Chris2581]
#647219
04/21/10 04:40 PM
04/21/10 04:40 PM
Posts: 2,560 S.E. Michigan
cl440
S.E. Michigan
$53.00 each?!?!!??!
[Re: cl440]
#647220
04/21/10 06:18 PM
04/21/10 06:18 PM
Chris2581
Jacksonville, FL
No,that was for a pair.Summit sells the 8519's for $17 and some change each,but Edelbrock should be ashamed of themselves.
[Re: Chris2581]
#647221
04/21/10 09:35 PM
04/21/10 09:35 PM
ProSport
Akron, Ohio
What??? I had them bring a set of Edelbrock's to the counter to look at and they were the white steel core laminate's.
Were your 8519's in an Edelbrock package?
[Re: ProSport]
#647222
04/22/10 04:21 PM
04/22/10 04:21 PM
Chris2581
Jacksonville, FL
YES!! Evidently Edelbrock is using Fel Pro as their supplier now.Not really a big deal as my combo is mild... only 9.2 compression.
Now Summit went above board on this as they refunded the difference between the price of the Eddy gaskets and what they sell the 8519's for and said to keep the "Edelbrock" gaskets,and I didn't ask them to do that.
[Re: ProSport]
#647223
04/22/10 07:01 PM
04/22/10 07:01 PM
CompWedgeEngines
Syracuse,NY
I'll say it again:
Quote: "There have been/is a mix of blue and white gaskets. For a while, you didnt know which ones you may get".
Same went for Ebrock, When supplies got limited, they went with Fel pros.Could have gotten either.
ROL is not a very consistent company to deal with . I explained it all early on, that they are a very " in flux" company right now.
RIP Monte Smith
