Question on motor mounts #644328
03/18/10 06:14 PM
03/18/10 06:14 PM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
My '71 Charger came with a 400 which was not worth repairing and is being replaced by a 440.
What are the 'ears' called that connect the engine block to the motor mount? The ones that were on the 400 do not line up with holes on the 440. Where can I order them from?
Re: Question on motor mounts [Re: whitemtnelf] #644329
03/18/10 06:17 PM
03/18/10 06:17 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Something is not right. The mounts from the 400 should be the same...
Re: Question on motor mounts [Re: whitemtnelf] #644330
03/18/10 06:17 PM
03/18/10 06:17 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
They should be the same. Check and see if you have them on the wrong side. There is a left and a right. As far as i know all b and rb motors had the same mount brackets
Re: Question on motor mounts [Re: Dougsmopars] #644331
03/18/10 07:11 PM
03/18/10 07:11 PM
New Hampshire
W
W
New Hampshire
DOH! I did have them on the wrong side. The thing that got me confused were the bottom holes on the connectors.
On the left connector both of the top holes line up with the top tab on the block and both of the bottom holes line up with the lower tab on the block.
On the right connector both of the top holes line up with the top tab on the block. However only one hole lines up with the bottom tab. The lower hole on the back side of the connector is about 1/2 inch too high.
