Clutch adjustment #643952
03/18/10 11:55 AM
03/18/10 11:55 AM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
When adjusting the clutch at the flywheel with a feeler gauge what should the distance be?
Re: Clutch adjustment [Re: gts1] #643953
03/18/10 12:19 PM
03/18/10 12:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Depends on the type of clutch?....diaphram, BB, BBL, dual disk?, Marcel, no Marcel?...more info needed
Re: Clutch adjustment [Re: DAYCLONA] #643954
03/18/10 12:35 PM
03/18/10 12:35 PM
Ct
gts1 Offline OP
gts1  Offline OP
Ct
Stock BB 101/2 Ram replacement 65 Valiant 273 with 70 bellhousing & Trans installed
Re: Clutch adjustment [Re: gts1] #643955
03/18/10 02:55 PM
03/18/10 02:55 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
cool stuff.the old direct connection racing manual bible says o.60" between flywheel and disc.
