Horn Pad Question #64293
05/26/08 10:04 PM
05/26/08 10:04 PM
Anonymous OP
Anonymous OP
I have a '69 BBody. I have a replacement steering wheel I believe out of a '70?(it has a rubber grip not bakelite or whatever it is on the original) However the horn pad and horn ring is one unit. How can I attach the pad with the steering wheel? On my current steering wheel it's two peices, the pad and the horn ring. The ring screws to the horn actuator and the pad bolts to the ring. With the replacement pad I have no way of securing the pad to the steering column?
I'd like to use the pad off the replacement steering wheel. Hope I explained it enough. Any help would be appreciated.
Re: Horn Pad Question #64294
05/27/08 11:53 AM
05/27/08 11:53 AM
Ohio
dobie Offline
dobie  Offline
Ohio
I have a a 68RR and wanted to use a 69RR style horn pad. I had to buy a complete 69 wheel and then take the guts and mount them to my 68 wheel. After that, the 69 pad fit right on. I'm not too sure on what a '70 model involves, as I had been under the impression that they are different altogether.
1968 Plymouth Road Runner 383 4 speed
Re: Horn Pad Question #64295
05/27/08 12:43 PM
05/27/08 12:43 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Without a picture It is hard for me to picture what you are talking about but I think you need the adaptor at the bottom of the this thread
https://board.moparts.org/ubbthreads/show...rue#Post4414817
I just went to osh and $2 later I made my own.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Horn Pad Question [Re: HealthServices] #64296
06/02/08 11:49 PM
06/02/08 11:49 PM
Anonymous OP
Anonymous OP
Thanks for the help...I'll see if I can line up some photo's to better describe the problem.
Re: Horn Pad Question #64297
06/03/08 09:17 PM
06/03/08 09:17 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
is the horn ring adaptable to an E body ?
if so , which horn ring should i use?
