Re: 235 or 255/60x15 M.T. ET Street Radial on 70 Duster
[Re: JCCuda]
#641729
03/16/10 02:17 PM
03/16/10 02:17 PM
moparpollack
Lil Herman
Lil Herman
85086
On my 70 Dart 245/60/15 on a 15" wheel with 4.5" backspace fit with room. I would go with the 255/60/15 on a Duster.
[Re: JCCuda]
#641731
03/16/10 03:56 PM
03/16/10 03:56 PM
Posts: 4,084 Indiana
W5Duster436
Indiana
I have 255/60/15's on mine with 15x7 4" bc rallyes with no problems at all.
I am going to 15x10 5.5BS and 275/60/15's soon.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: JCCuda]
#641735
03/16/10 05:54 PM
03/16/10 05:54 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Lots of guys dont know what the first numbers actually mean...Its actually a measurement of the sidewall/bead up the side wall to the center of the tires in Metric units. So the larger first numbers always means both increase in height, and also foot print... I always put the largest set of tires possible when I order, of coarse taking in account gear also. Said that there's not going to be a bunch of diff between the two..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: JCCuda]
#641736
03/16/10 06:50 PM
03/16/10 06:50 PM
W5Duster436
Indiana
They look like they fit nice. Do you know what the backspacing is on your 15x7's and what diameter the tires are? How much room between the tire and the spring? And finally do you have any pics. of the car from behind?
I think those rims only come with one backspace IIRC. I have no idea what it is either. There is plenty of room and height for a 255/60/15 on your car. No problems whatsoever. I know guys running the 15x7 with 275/60/15's with no modifications. They are pretty tight up to the leafs though.
I can run outside and snap some pics of the 255's but trust me there is no problem running them. If you already have 15x7 with SBC on your car then you have the same rims I have. 255's I believe are ~27.05 diameter.
I am actually going to be copying 67Wedge's son's duster. I think they ran 15x10 w/5.5BS and 275's without even moving the leaf springs. It is the best looking stance I have ever seen on a duster. I'll attach a pic of it for you. PM 67Wedge for more info.
[Re: W5Duster436]
#641737
03/16/10 07:06 PM
03/16/10 07:06 PM
W5Duster436
Indiana
Here are some pics of mine. Forgot to measure but i'd say 1/2-3/4" clearance to the leafs.
[Re: W5Duster436]
#641738
03/16/10 07:07 PM
03/16/10 07:07 PM
W5Duster436
Indiana
Never even noticed until i took this picture that at some point the lips were finessed..
[Re: W5Duster436]
#641740
03/18/10 05:33 PM
03/18/10 05:33 PM
Posts: 486 IL
knyech1
IL
Not true. The first number is the WIDTH, in millimeters. The second it the aspect ratio, a number representing a percentage of the width, which gives you the sidewall height from rim edge to top of tire. Say you have a 225/60R15; 225 is 8.86" WIDE and 60% of that is 5.316", so you double that (10.632"), add your rim height (15"), and you have your tire HEIGHT, which in this case would be 25.632"
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
[Re: knyech1]
#641742
03/18/10 06:49 PM
03/18/10 06:49 PM
W5Duster436
Indiana
Yep, a 225 would be that and a 255 would be 27.05 exactly as I stated. ??
[Re: W5Duster436]
#641744
03/20/10 01:23 PM
03/20/10 01:23 PM
Posts: 486 IL
knyech1
IL
In this particular case, yes. I was just making it clear, because it seemed to me that you were implying that "255's...are ~27.05in diameter", which is exactly what you wrote and nothing more to explain that you were talking about that particular tire size of 255/60R15
