Speedometer cable wows! #63967
05/26/08 03:44 PM
05/26/08 03:44 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
I pulled the speedometer cable from the rear of my cluster so I could pull the cluster and fix some dead bulbs. That went well and all works, except now the speedometer goes crazy and all over the place! I re-pulled the cable a few times thinking it wasn't set correctly, but nothing helps. It was working fine before I pulled the cluster.
Any ideas? Thanks!
Re: Speedometer cable wows! [Re: polkat] #63968
05/26/08 03:50 PM
05/26/08 03:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Pull the core from the cable. Wipe it clean and lube it with vasoline, graphite, or a light grease.
