1968 Hemi Numbers Matching questions....... #63910
05/26/08 01:59 PM
05/26/08 01:59 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Have any of you ever seen and have undeniable proof of any original factry 1968 Hemi car having the VIN sequence number stamped into the transmission and the SO # stamped into the engine block (rather than the VIN seq number as the trans had) on the same car? If you do please e-mail me or post pictures of the stampings.
On a similar note, if you have phots of any SO number stampings (rather than VIN seq# stampings) on any 68 Hemi car engine or transmission I'd like to see pictures of those as well.
Thanks!
Re: 1968 Hemi Numbers Matching questions....... [Re: ScottSmith_Harms] #63911
05/27/08 06:45 PM
05/27/08 06:45 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Scott,
This is a great topic about the 1968 models. I would even like to expand the question to the following for any engines:
1. The date when the S.O. number was changed over to the VIN by assembly plant.
2. Date when the full VIN was chaned to the last 8 digits.
Lynch Road Assembly
LA Assembly
Hamtramck Assembly (Dodge Main)
St. Louis Assembly
www.mmcdetroit.com
www.iccahome.org
Re: 1968 Hemi Numbers Matching questions....... [Re: MMC Detroit] #63912
05/27/08 09:36 PM
05/27/08 09:36 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Scott,
I only have the original trany for my Hemi Road Runner and it will be a few days before I can take a picture of it for you. I can contribute the following information. My 68 Road Runner was a Lynch Road car with a build date of 4 May 68. The SO is 287580. The rail info is PK 2801544K 2413 0178 (6 March 68, #178 that day) Top of the case is stamped 8A2 87580.
Hope the info helps.
