Clutch trouble? #63663
05/26/08 09:07 AM
05/26/08 09:07 AM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
In my 70 Road Runner 383 four speed, the clutch has become anything but smooth upon engagement in first gear. Really have to finese it to keep it from vibrating the car like crazy. Is it going bad and can I nurse it for a couple of thousand miles before replacing it and doing other things under the car while I'm at it this winter.
Any thoughts?
Re: Clutch trouble? [Re: JeffRacerG] #63664
05/26/08 09:26 AM
05/26/08 09:26 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
wwhats is going on? it vibrates? could be anythimng drivetrain related?
do you just bang the gears , or be the stall ?
were there any high spots on the flywheel when you rotated it ?
did you recheck the bolts tightness, after a few heat cycles. flywheel, starter, pressure plate?
Re: Clutch trouble? [Re: mark7171] #63665
05/26/08 10:09 AM
05/26/08 10:09 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Clutch chatter usually means replacement time. All that vibrating is coming from hard spots on the flywheel and a bad clutch disk face. You will eat up the flywheel if you keep running it. You should be able to swap the clutch in a day with out working too hard.
