Need to know if this oil pan will fit
#63620
05/26/08 05:56 AM
05/26/08 05:56 AM
Posts: 4,280 Danville, NH
Mopar_Mike
Danville, NH
I have a 971 oil pan, 1973-4 B-body 400 or 440. The pan has been extended to be a 7-quart pan. Just need to know if it will clear ok in my 67 Coronet.
RS23L7 4-Speed
Re: Need to know if this oil pan will fit
[Re: Mopar_Mike]
#63621
05/26/08 06:10 AM
05/26/08 06:10 AM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
Make sure the sump area clears the center link in a 66-70 B-body. The 62-5 Bs and the 73-4 Bs both use a pan with the sump area a little further back to clear the K frames.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
