Page 3 of 3 1 2 3
Re: Another Eagle cast crank broken (408 stroker) [Re: Mike Swann] #634697
08/27/11 07:06 AM
08/27/11 07:06 AM
Guitar Jones Online laugh2
I've seen that too, in fact the guy that did machine work for me had one in a 11.00/10.90 A body with an automatic and it broke the same way.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Another Eagle cast crank broken (408 stroker) [Re: Guitar Jones] #634698
08/28/11 10:25 PM
08/28/11 10:25 PM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
Just another example of people not following the recommended HP ratings for these cranks. A 3000lb A body with a 200lb drive will go 11.40 with a 500HP engine.
In other words, your machinist was making around 540-550HP to run 10.9's with the cast crank. Is it any wonder it failed? Clearly with that type of HP the motor should have had a forged crank.
Re: Another Eagle cast crank broken (408 stroker) [Re: dr.mopar] #634699
08/28/11 11:07 PM
08/28/11 11:07 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
It doesn't take 500hp to run 10.90's @3200lbs. I tried to use an eagle cast crank in my daily driver truck,but in 10 minutes after it showed up I had in back in the box for return. I was not able to save my buddy as he used this crank for almost 2 seasons,running 11.00 @ 3200lbs then it came apart and destroyed a lot more than the crankshaft. Good luck.
Re: Another Eagle cast crank broken (408 stroker) [Re: goldmember] #634700
08/29/11 12:30 AM
08/29/11 12:30 AM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
I will agree to disagree, in my opinion it takes all of 500+ horsepower to run 10.90's in a 3200lbs door car and the need for a forged crank is obvious in such a fast car. If the friend got two yrs. out of the deal I would say he did pretty good considering the crank is on the ragged edge of its recommeded range.
Re: Another Eagle cast crank broken (408 stroker) [Re: CJK440] #634701
08/29/11 12:43 AM
08/29/11 12:43 AM
PA
moparacer Offline
moparacer  Offline
PA
Thats the second one i saw that broke the snout. After examining the one I had, I thought the weak point was the rear arm/journal cross section especially with all 8 cylinders twisting it.
Thats were ours broke at 100 passes and no street miles.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Another Eagle cast crank broken (408 stroker) [Re: dr.mopar] #634702
08/29/11 12:54 AM
08/29/11 12:54 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I will agree to disagree. It does not take a forged crank to withstand that output. Just a factory cast crank or a cast MP/Scat crank and you'll have far better odds of a reliable engine,rather than a potential disaster. The engine in the duster was less than 500 hp(yes, it was on the dyno),so give me some idea how long that crank might last @ 450hp,475hp,etc I'd love to know the answer.I'll just keep putting better cranks in my builds and sleep better.
Re: Another Eagle cast crank broken (408 stroker) [Re: goldmember] #634703
08/29/11 01:29 AM
08/29/11 01:29 AM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
Not all dyno's are created equal, just ask Hughes. At 450HP the eagle cranks are lasting a very long time, 7+ yrs. which is a long time in the life of most street strip rides.
In fact I just got 7 yrs. out of a 360 which had two cylinders cracked. Was it the blocks falt these cyls cracked? Who knows, however it didn't help that I overheated it a yr. ago when it started leaking fluid. So which came first the crack, or the overheating which likely led to the cracks?
What did I put back in? Another 360 because they make great drag motors with or without a stroker crank..
Re: Another Eagle cast crank broken (408 stroker) [Re: dr.mopar] #634704
08/29/11 01:36 AM
08/29/11 01:36 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Yep, I'll call Hughes in the morning so that I can be truly informed.
Re: Another Eagle cast crank broken (408 stroker) [Re: goldmember] #634705
08/29/11 01:39 AM
08/29/11 01:39 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
just love that duster
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Another Eagle cast crank broken (408 stroker) [Re: Stroker Scamp] #634706
08/29/11 12:13 PM
08/29/11 12:13 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I agree..we need more pics and details please.
Re: Another Eagle cast crank broken (408 stroker) [Re: goldmember] #634707
08/29/11 11:18 PM
08/29/11 11:18 PM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
I will agree with you on this, Hughes is not all they are "cracked" up to be..
Interesting to note Mancini racing sell three different brands of cranks including cast eagles.
Things that make you go hummm? If eagle cast cranks were such an issue why would one of the top Mopar houses carry this product?
When you call the Hemi hot line they have no ill feelings about anyone using cast eagle cranks and have no mass reports of eagle crank failures?
To me this whole post was likely started by a few ill informed Scat fans.
According to my local speed shop it is Scat that is having the quality control issues, not Eagle.
Re: Another Eagle cast crank broken (408 stroker) [Re: dr.mopar] #634708
10/01/11 09:30 PM
10/01/11 09:30 PM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
Latest update, our 408 with the eagle cast crank went 11.93 @ 111.4 in our 3600lb b-body satellite today.
Boy am I happy..
Re: Another Eagle cast crank broken (408 stroker) [Re: dr.mopar] #634709
10/01/11 11:29 PM
10/01/11 11:29 PM
Boy am I happy..
And of course when it breaks you'll update us on that as well right?
Re: Another Eagle cast crank broken (408 stroker) [Re: Guitar Jones] #634710
10/02/11 12:13 AM
10/02/11 12:13 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Boy am I happy..
We can hope he does. I'll make a deal with him,I'll report back when the stock 360 cast crank breaks,it's been 100,000 street miles and makes 10 second passes without a second thought @ 3600lbs. We have hundreds of passes on this junk so you better get busy.
Re: Another Eagle cast crank broken (408 stroker) [Re: goldmember] #634711
10/02/11 01:00 AM
10/02/11 01:00 AM
Boy am I happy..
You can see the numbers in my sig, that's 15 years of 7000 rpm shifts on a stock 360 crank. If he get's even a quarter of that I'll be surprised.
Re: Another Eagle cast crank broken (408 stroker) [Re: Guitar Jones] #634712
10/02/11 10:42 AM
10/02/11 10:42 AM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
Lets see, race car compared to street car, kind of an apple and oranges thing don't you think. W5's? It better run 10's.
If you want to compare apples to apples lets do it. I unbolted all the parts from my J headed 360 and installed them on a street 408. Installed in the same car and it picked up 6 tenths. Worth it? certainly.
Bottom line, no one said the 360 crank wasn't good, in fact it is awesome. I'm just saying to the anti eagle crowd there is nothing wrong with the 4" Eagle cast crank if used as recommended..
Page 3 of 3 1 2 3
