Replacing Fuel Tank Sending Unit on a B-Body?
#63336
05/25/08 05:37 PM
05/25/08 05:37 PM
Hello, I would like to replace my fuel tank sending unit on my '70 B-Body. I wanted to know if I need to buy anything additional other than the unit? Will I need special gaskets or seals when doing the replacement?
Also, if anyone has done this before -- Do you have to drain the gas tank (or remove it) in order to do this procedure?
Thanks very much!
Re: Replacing Fuel Tank Sending Unit on a B-Body?
#63337
05/25/08 06:39 PM
05/25/08 06:39 PM
Posts: 5,117 Haslett, MI
7DRRunner
Haslett, MI
I swapped one in my 70 RR last year I bet you could do it without taking the tank down, and when you buy a new sending unit, it comes with the gasket you need I went ahead and dropped the tank because it had a ding in it I wanted to take care of at the same time you shouldn't need any special tools, but even if you don't drop the tank, I think you should not go about it with a full tank
"Good luck on your project."
1970 Road Runner
"Accellertii Incredibus"
[Re: mopar346]
#63339
05/25/08 08:14 PM
05/25/08 08:14 PM
Thanks Guys!
Does anyone have a recommendation of a good place to order one of these? One that is reliable and comes with the necessary gasket(s)?
Thanks!
#63340
05/26/08 02:23 PM
05/26/08 02:23 PM
Hi Guys,
I've seen one of these for sale online -- says it takes a 3/8" "fuel feed" for B-Bodies. Does this sound like the correct one?
And, is there any type of adjustment you need to make to the unit once you put it in the tank to get the correct readinds? Something like a calibration so it knows the level ...or does it just know the level based on the length of the unit?
Thanks!
#63341
05/26/08 03:50 PM
05/26/08 03:50 PM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
the one I got didn't need any calibration. Tested outside the gas tank and got correct readings
Got from VANS AUTO SALVAGE, with metallic strip instead a wire, and brass floater, like the original.
Only issue what I didn't like is the outlet is straight and my original was allmost 45º, what did make better hose fitment
