Dana 60 Gear Oil? #63333
05/25/08 05:33 PM
05/25/08 05:33 PM
Anonymous OP
Anonymous OP
Hello,
Just curious ... on a Dana 60 rearend, do you generally use the same gear oil as a typical 8 3/4 posi? (eg. 90-140W) ?
Thanks!
Re: Dana 60 Gear Oil? #63334
05/25/08 05:38 PM
05/25/08 05:38 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
yes go to walmart and get some Super Tech 75/140 full synthetic gear oil for $9.50 per bottle and some ls additive from autozone a 7 oz bottle is $4.50 use about 3 or 4 oz save the rest for your next oil change.
Re: Dana 60 Gear Oil? [Re: ademon] #63335
05/26/08 02:33 PM
05/26/08 02:33 PM
Anonymous OP
Anonymous OP
Ok, Thanks a lot!
One more easy one -- For these Dana 60's - same as 8 3/4's and manual trans -- I just need to take out the plug and see if I can touch any fluid with my index finger to see if it's up to full level, correct??
Thanks!!
