64 Max Wedge choke questions
#633203
03/07/10 08:56 PM
03/07/10 08:56 PM
Posts: 7,195 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Hi Guys...Just got a 64 max wedge in the shop with the original 3705 carbs...It was set up for racing and now I'm putting it back to original condition with the choke equipment in place.. Getting all the parts and info together...Was there any linkage for a fast idle on these??? Any pics would be very helpful...
Re: 64 Max Wedge choke questions
[Re: screamindriver]
#633204
03/07/10 09:18 PM
03/07/10 09:18 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yes, they have fast idle linkage on the throttle lever side of the carb just like the automatic choke carbs but a cable bracket and lever replace the choke thermostat on the opposite side.
#633207
03/11/10 10:59 AM
03/11/10 10:59 AM
Posts: 5,160 Texas
dannysbee
Texas
Here are a couple of pictures.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#633208
03/11/10 11:09 AM
03/11/10 11:09 AM
Posts: 5,160 Texas
dannysbee
Texas
Picture 2. Would you post a picture of the firewall and grommet. Thanks
[Re: dannysbee]
#633209
03/11/10 11:12 AM
03/11/10 11:12 AM
Posts: 5,160 Texas
dannysbee
Texas
Original carb tag picture.
[Re: ScottSmith_Harms]
#633211
03/11/10 11:31 AM
03/11/10 11:31 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Choke Side (choke cable clamp not attached, cable nut and arm are reproductions). If you need parts Norm Brady nbrady@crossramconnection.com can probably help you, he has a bunch of nice reproduction parts as well as originals, he also makes a nice reproduction carb tag for 3705's that now have the correct ribs, etc.
#633212
03/11/10 11:42 AM
03/11/10 11:42 AM
Posts: 5,160 Texas
dannysbee
Texas
Scott where is the choke cable bracket?
#633214
03/11/10 06:58 PM
03/11/10 06:58 PM
John_Kunkel
Rio Linda, CA
Excuse the brain fart in my first reply, I forgot that I ran 9755's on my MW clone.
#633216
03/11/10 08:30 PM
03/11/10 08:30 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem on the pics, and thanks for the props. I am pretty sure I know that car, it looks like the same one we had on the lift at the ICCA Judging tent at Mopars At The Strip a while back? I have a ton of detail pics of that car, some details right, some wrong, but regardless, it's a very nice car. It had a 64 Max Wedge block in it at the time but I believe it's had an engine swap since then to a correct 63? Do your carbs have stamped in numbers on the feet or not? Are the tags 3705S or 3705SA? *John, don't sweat it man, we all know that you have your MW stuff down!
