original cooling fan & clutch #63287
05/25/08 03:37 PM
05/25/08 03:37 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
hi guys would appreciate any help please .. whats the part number for the cooling fan & clutch ..for a 69 charger R/T... 26 " radiator ..& A/C .. any body have a picture of one ..also any source on NOS for these ?? .. also .. new MP 5 blade fans . ..are they more efficent / better at cooling then the original 7 blade ones ?? ...
thanks for you help
Re: original cooling fan & clutch [Re: A47] #63288
05/26/08 03:23 PM
05/26/08 03:23 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
Re: original cooling fan & clutch [Re: A47] #63289
05/26/08 09:05 PM
05/26/08 09:05 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
fan is 2863216, clutch is the thermal type 2863260 7.25 inch diameter
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: original cooling fan & clutch [Re: A47] #63290
05/27/08 11:05 AM
05/27/08 11:05 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
I replace a fixed 7 blade fan with a 5 blade fan and clutch setup. Seems to pull same amount of air and the temperature runs the same. The 5 blade fan is alot lighter than the 7 blade fan. In my experience, you could not go wrong changing to 5 blade fan/clutch setup. I picked up mine off ebay for $40. The individual part nos. are Fan 4140063 and Clutch 4095704.
Ron
Re: original cooling fan & clutch [Re: Ronnman] #63291
05/27/08 11:11 AM
05/27/08 11:11 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Ron
Except that clutch is too long and will place fan too close to rad if used with the 2863216 fan on a 69 B body
Re: original cooling fan & clutch [Re: AZ_A12_BEE] #63292
05/27/08 04:42 PM
05/27/08 04:42 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thanks for the information guys it has been appreciated
