Re: DUSTER WIRING PROBLEM
[Re: 71_deputy]
#63244
05/25/08 07:17 PM
05/25/08 07:17 PM
Posts: 32,920 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Disconnect the + battery cable and clip your test light between the cable and the battery post. If every thing is off and the doors are closed the test light should not light. If it does you have a draw. Start tracing it by pulling the fuses one at a time until the light goes out. If it doesn't go out then start looking for unfused things.Like the alt,starter relay, head lights, brake lights, etc.
[Re: stumpy]
#63245
05/25/08 10:09 PM
05/25/08 10:09 PM
Posts: 435 so cal,cali
calimoparguy
so cal,cali
tried that and when i pull the number 4 fuse out the test light goes out??
anyone happen to have a wiring diagram for the fuse box that tells what each fuse is for??
[Re: calimoparguy]
#63246
05/25/08 11:19 PM
05/25/08 11:19 PM
Andrewh
[Re: 71_deputy]
#63247
05/25/08 11:21 PM
05/25/08 11:21 PM
Posts: 3,312 Marine Corps Base Hawaii
DemonKyle
USMC LCPL
USMC LCPL
if everything is off- and that is also the dome light- the alt's diodes could be bad!
That would be the easiest thing to have checked first. Take it off and down to a local Kragens or AutoZone and have it checked
[Re: calimoparguy]
#63248
05/26/08 12:18 AM
05/26/08 12:18 AM
Are you going to tell us the model and YEAR you are working on, or should we ship you off to Guantanamo?
You can tell which fuse it is, by hooking up the battery, turning on the key, and then pulling and reinstalling the fuse--and figure out what else goes on/off with it.
The ignition and regulator circuit is not fused, so at this point I doubt that it's diode problems.
[Re: calimoparguy]
#63251
05/26/08 12:42 AM
05/26/08 12:42 AM
its a 73 duster,318,auto,non a/c.
Cool. Here's the diagrams:
http://www.mymopar.com/downloads/1973/73ValiantA.jpg
http://www.mymopar.com/downloads/1973/73ValiantB.jpg
Now, hook the battery cable back up, turn on the key, and turn on some things in the car, the wipers, radio, turn signals, etc. Pull the fuse and see what stops working.
Don't forget to check the lighter!!!
Check for lamps, like glove box, underhood, and trunk.
Also, when you check the suspect fuse, does the test lamp go out, with this fuse pulled, and is the ignition switch on or off?
#63252
05/26/08 12:46 AM
05/26/08 12:46 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Also... whne you are checking, are doing with door open or closed ? so then, dome light and any courtesy light including time delay controled ? that fuse could it be for those what if you are checking with doors open and remove that fuse could cut the power for dome light, then OF COURSE you'll have consumption there allways
#63255
05/26/08 03:46 PM
05/26/08 03:46 PM
stumpy
Grand Prairie,Texas
already answered
