Page 6 of 6 1 2 3 4 5 6
Re: New Edelbrock Carb Issues. [Re: SomeCarGuy] #632038
03/25/10 02:43 AM
03/25/10 02:43 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
750 3310, 750 3310, 750 3310, 750 3310!!!!!!!!!!!!
I'll say it again! 750 3310 & BE DONE!!!!!
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: New Edelbrock Carb Issues. [Re: moper] #632039
03/25/10 06:11 AM
03/25/10 06:11 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Holleys are just a little simpler and more crude in terms of operation over the Carter design. If they work for you best, great. It doesnt matter who made the carb. You can make the same power when the carb, any carb, is properly set and matched to the combo.
I'm using 2 Edelbrock 750's because the Nostalgia Super Stock rules require me to. Never have hard start or hesitation situations. They've always worked great.
Re: New Edelbrock Carb Issues. [Re: actionange] #632040
03/25/10 06:44 AM
03/25/10 06:44 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I never figured out why but both the new Eddy 750 and 600 I bought had hard strat issues when hot. To pinpoint I:
1). Put a 1/2 inch phenolic spacer under the carb and wrapped the new steel fuel line I ran from the pump to the carb. As directed by Eddy's techs.
2).I checked the heat riser valve to make sure that was open.
3).I did pop the top on the 600 and readjusted the float bowls to Eddy's specs. They were out of spec.
4).I ran fuel line hose only from the pump to the carb to totally get rid of the steel. This an attempt to put everything back the way it was before I got the Eddy 750.
5). Took my Carter AFB off my 68 Bee and put it on my 69. Issue went away.No hard start when hot.
6). Put a fuel pressure regulator on with gage and set to 4.5 psi with the Eddy 600 back on. Still no hot start.
7). Rebuilt the old 600 Holley that I took off my 69 to replace with the Eddy 750. Have ran the car now for almost a week. No hard start problems.
I only gave up on the Eddy 600 after almost getting stuck somewhere and not being able to get the car started. I had a hard time with the fact that 2 new carbs were doing the same thing. But.... 2 old carbs work on this car. 2 different brands also. After all this I'm going with a Holley.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: New Edelbrock Carb Issues. [Re: TimS] #632041
03/25/10 11:35 AM
03/25/10 11:35 AM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
Have you tried the Edelbrock #1407 750?
...kidding
Re: New Edelbrock Carb Issues. [Re: SomeCarGuy] #632042
03/25/10 11:43 AM
03/25/10 11:43 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Why not a 750?
You said stock.
Modified I'd go with the 3310 Holley 750!
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: New Edelbrock Carb Issues. [Re: HitIt] #632043
03/25/10 12:23 PM
03/25/10 12:23 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Na. I've had enough of the Edelbrock carbs. I'll pass on that.
Re: New Edelbrock Carb Issues. [Re: Junky] #632044
03/25/10 01:22 PM
03/25/10 01:22 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Why not a 750?
You said stock.
I've run 3310s on mild 360s, it'll work great on a 383, even a stock 383. There are quit a few that had issues with the street avanger, its been all over these boards, the 3310 is tried & true, the only other T&True is the 600 1850, be he will be much happier with the 750 on that 383 IMO, but to each his own i guess.
Re: New Edelbrock Carb Issues. [Re: joedust451] #632045
03/25/10 04:26 PM
03/25/10 04:26 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
The 4160 series 600 on it now seems to work pretty well. I was just thinking of going for one a little bigger.
Re: New Edelbrock Carb Issues. [Re: TimS] #632046
03/25/10 04:55 PM
03/25/10 04:55 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
You will be impressed up-grating to the 3310 over the 600 1850 on that 383, not that the 600 won't work, but you'll get power all around with the 750. Obviously you must have noticed an improvement with the larger Eddy carb despite its issues, thats why your wanting more CFM. If you go on e-bay, you can find a bunch of good used 3310 750s for cheap, I got mine for 113.00 to my door, & it was hardly used, its alot cheaper going this way then buying new.
Re: New Edelbrock Carb Issues. [Re: joedust451] #632047
03/25/10 05:20 PM
03/25/10 05:20 PM
scratchnfotraction Offline
buying used can be a gamble also
carbs on ebay
not saying..just saying
you know what you gots when its new and better recorse if defective
Re: New Edelbrock Carb Issues. [Re: joedust451] #632048
03/26/10 04:58 AM
03/26/10 04:58 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I see what you mean about buying used but that's a 50/50 proposition. You take your chances on a carb. Like the guy that used to have my 69 bought a model # correct Carter from a swap meet and was told it was ready to go. NOT.What kind of money is a 3310 750 new? I agree, even with the Eddy's hot start issues that jump to the 750 made this 383 haul A--. That's why I'm considering a new carb still to get more CFM.
Re: New Edelbrock Carb Issues. [Re: TimS] #632049
03/26/10 07:45 AM
03/26/10 07:45 AM
NL
Frederick Offline
Frederick  Offline
NL
Here's an article about how to get rid of the Edelbrock stumble.
http://webrodder.com/article.php?AID=522&SID=60
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: New Edelbrock Carb Issues. [Re: joedust451] #632050
03/26/10 08:37 AM
03/26/10 08:37 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
That Holley 3310 series 750 appears to be comparable cost wise to the Edelbrocks in the Jegs catalog.
