Axle assembly question ; #63083
05/25/08 09:47 AM
05/25/08 09:47 AM
North Florida
RebelDart Offline OP
super street
super street
North Florida
I purchased this setup over two years ago, unassembled so I have a couple questions: I believe I have the Green bearing setup as both sides look identical (no adjuster) and there's an "O" ring seal on the outer bearing keeper. I have assembled third member, axles, brake assemblies and housing. I'm assuming assembly is pretty straightforward, axles simply slide in w/no adjustments needed (so simple even a caveman can do it ) ? Thanks for any input - also have 3/4 spring relocation kit, perches moved - what's the issue with the front spring hangers (I recall an issue with the bolts and haven't gotten that far yet ) ? Hope to have all installed today.
Re: Axle assembly question ; [Re: RebelDart] #63084
05/25/08 03:39 PM
05/25/08 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I prefer to remove the thrust block or buttons from the differential when using the Green bearings, if the dimensions of the housing or axles are a little off the buttons/block will place a constant side load on the bearings causing them to fail prematurely.
Re: Axle assembly question ; [Re: John_Kunkel] #63085
05/25/08 10:16 PM
05/25/08 10:16 PM
North Florida
super street
super street
North Florida
This may have been done already - if you could clarify what I'm looking for - I've got a couple manuals to reference showing stock setup, but it looks as if these were changed to greens which I have never seen before. thanks.
Re: Axle assembly question ; [Re: RebelDart] #63086
05/26/08 08:40 AM
05/26/08 08:40 AM
North Florida
super street
super street
North Florida
Re: Axle assembly question ; [Re: RebelDart] #63087
05/26/08 11:37 AM
05/26/08 11:37 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Order of assembly starting at housing end:
1. Beaded steel gasket
2. Brake backing plate
3. Black foam gasket
4. Green wheel bearing
5. Wheel bearing retainer
Lube the O rings. This makes installation easier.
Re: Axle assembly question ; [Re: DoctorDiff] #63088
05/26/08 12:19 PM
05/26/08 12:19 PM
North Florida
super street
super street
North Florida
Thanks a bunch - couldn't ask for a more qualified answer !
