68 GTX front buckets. #63059
05/25/08 08:27 AM
05/25/08 08:27 AM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
'Tore down my front seats yesterday and got the lower frames cleaned, up sanded and a coat of paint on. I have new covers, foams, hinge covers, headrests, and bezels. I noticed the factory burlap has a series of wires running through it attached to cords on the edges. I suppose it's to keep the burlap from pushing through the seat springs? Do you guys try to replicate this or should I just hog ring my new burlap to the seat springs, install the foam and covers and call it done? Thanks!
Re: 68 GTX front buckets. [Re: Silverbullet2] #63060
05/25/08 09:01 AM
05/25/08 09:01 AM
PNW
Danan Offline
Danan  Offline
PNW
I replicate it whenever possible. If the seats have been "restored" in the past, the burlap and those wires are usually long gone. In either case, I purchased several yards of a very strong fabric that the local upholstery guys use instead of the burlap. It is far stronger and longer lasting, but doesn't look stock. I install the burlap (with or without the wires) and then lay the fabric mentioned above over that. Looks stock and is more durable than burlap alone.
Re: 68 GTX front buckets. [Re: Danan] #63061
05/25/08 09:35 AM
05/25/08 09:35 AM
North Carolina, USA
North Carolina, USA
Thanks Danan,
I had these recovered back in the 80s but about all hey did was covers and build up the old padding a little. Another question does anyone have new seat backs for the 68-69 seats? One of mine is broken and I'm also changing colors too.
Re: 68 GTX front buckets. [Re: Silverbullet2] #63062
05/25/08 03:37 PM
05/25/08 03:37 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
You can get the backs from legendary, you'll have to reuse the hook thingys though unless someone has started repopping them.
I can't afford this. mark
