Alternator Mount - when using Meziere water pump #629387
03/02/10 11:46 PM
03/02/10 11:46 PM
Garland, Texas
1badmopar Offline OP
Garland, Texas
I am in need of an alternator mount for my RB that will work with a Meziere electric water pump. The factory bracket will not longer work, since it bolts to the front of the factory pump housing.
Any suggestions?
Thanks,
Bridger
1966 Plymouth Belvedere
520" RB w/ Indy 440-1 Heads
FiTech Fuel Injection
TKO 600 conversion
[img]https://flic.kr/p/2j1ejsK[/img]
Re: Alternator Mount - when using Meziere water pump [Re: 1badmopar] #629388
03/03/10 02:25 AM
03/03/10 02:25 AM
Boise
Moparteacher Offline
Boise
Re: Alternator Mount - when using Meziere water pump [Re: Moparteacher] #629389
03/03/10 04:46 AM
03/03/10 04:46 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Sorry to hijack but will the DMI brakets work with the stock alternator.
Mick
Re: Alternator Mount - when using Meziere water pump [Re: deaks] #629390
03/03/10 05:09 AM
03/03/10 05:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
if you use a plate it's easy.
Re: Alternator Mount - when using Meziere water pump [Re: rebel] #629391
03/03/10 08:15 AM
03/03/10 08:15 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Alternator & mount from Jegs. Alternator is std chebby 100a with Product Engineering 8mm cog pulley and a cut down blower pulley.
Re: Alternator Mount - when using Meziere water pump [Re: Dragula] #629392
03/03/10 09:09 AM
03/03/10 09:09 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Mine comes off the right elephant ear as well . Hey Dragula , how`s that front end holding up ? It looks like a MagForce unit .
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Alternator Mount - when using Meziere water pump [Re: deaks] #629393
03/03/10 10:56 AM
03/03/10 10:56 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Hey Deaks, the factory alternator will NOT work with the low mount Billet alternator bracket that Doty manufactures. Very nice pieces makes it worth switching to a single wire race alternator. There is a 100 amp GM style alternator that works on it with some minor shimming.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Alternator Mount - when using Meziere water pump [Re: PUNK] #629394
03/03/10 11:01 AM
03/03/10 11:01 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Thank you Sloan.
Mick
Re: Alternator Mount - when using Meziere water pump [Re: deaks] #629395
03/03/10 06:56 PM
03/03/10 06:56 PM
oregon
ramcharger1964 Offline
oregon
I ended up making my own brackets for the alt and water pump with my 500" RB with a Meziere. All the kits out there are for the mini alt's. I needed the BIG alt since I am running fan, H2O pump, fuel pump, trans cooler, etc on mine. It worked out pretty good so far - although I did throw a belt when it hit 8500rpm.....
Let me know and I can send you some pic's.
Hell B!tch Racing Co.
