Roller cam end play #629305
03/02/10 10:39 PM
03/02/10 10:39 PM
closer to Canadian beer!
torkrules Offline OP
I'm neurotic
I'm neurotic
What would you guys (or girls) say a proper roller cam end play should be. If it matters, its a Lunati mechanical solid cam.
Re: Roller cam end play [Re: torkrules] #629306
03/02/10 11:04 PM
03/02/10 11:04 PM
I'm neurotic
I'm neurotic
2G Hemi.
Re: Roller cam end play [Re: torkrules] #629307
03/03/10 12:10 AM
03/03/10 12:10 AM
I'm going to say no more than .015 and no less than .003 cold. Maybe some of the other builders will chime in. This is one of those numbers I try not to memorized, I call the cam maker and get there spec for the current thinking
Re: Roller cam end play [Re: torkrules] #629308
03/03/10 12:27 AM
03/03/10 12:27 AM
AndyF Online content
AndyF  Online Content
0.005 to 0.010 is the usual number.
Re: Roller cam end play [Re: AndyF] #629309
03/03/10 07:23 AM
03/03/10 07:23 AM
I'm neurotic
I'm neurotic
Thanks Cab/Andy. I got .006" cold, so i'll run with that.
Re: Roller cam end play [Re: AndyF] #629310
03/03/10 07:28 AM
03/03/10 07:28 AM
I'm neurotic
I'm neurotic
By the way Andy, Your button and cover will work fine with a Cloyes billet chain set and ARP 244-1001 bolts. The only thing I needed to do was turn the bolt head down .080" to clear the cover and get it below the button head. This still leaves enough meat on the bolt to get a 12 point socket on and torque them to 40lb.ft.
Thanks again.
Re: Roller cam end play [Re: torkrules] #629311
03/03/10 12:04 PM
03/03/10 12:04 PM
Thanks for the feedback. On my motors I use the special ARP header bolts. They have a small diamter head and are drilled for safety wire. They fit without any modifications in the hex-a-just timing set.
