Prepping e-coated panels prior to bodywork and primer #62714
05/24/08 09:20 AM
05/24/08 09:20 AM
Detroit, MI
FC7AARcuda Offline OP
Detroit, MI
What prep do e-coated panels need prior to bodywork or priming? Do I just scuff them up or sand down to bare metal?
Re: Prepping e-coated panels prior to bodywork and primer [Re: FC7AARcuda] #62715
05/24/08 10:08 AM
05/24/08 10:08 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Generally, I prefer to leave the E coat on the inside of the panel alone, and DA (sand w/ orbital sander) the outside surface, and completely remove the E coat that will see welding, perhaps bodywork, then etch prime, prime, block, paint,......if the panel is a trunklid, door or hood, then I remove the E coat finish from both sides, E coat is the poormans "powdercoat", it's merely an economical barrier to prevent tne panel from rusting from the manufacturer,, if it has to be maintained in inventory..........
Re: Prepping e-coated panels prior to bodywork and primer [Re: DAYCLONA] #62716
05/24/08 11:02 AM
05/24/08 11:02 AM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
To add, I have found on one occasion to be surface rust under the e-coat. May or may not have surfaced later - was glad I took it down to the bare steel.
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
