Re: Are 413 Engines really all that special?
[Re: AndyF]
#62391
12/10/09 01:09 AM
12/10/09 01:09 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
For you guys who think that 413's are scrap metal, explain to me why those 4500+ lb Newports and 300's run in the high to mid twelves all day long. They are modified of course, but do you get the concept. TORQUE is what gets you going 90% 0f the the time. And comparably speaking, the 413 can be made to RUN HARDER. Passenger car, motorhome or MAX-WEDGE. Does not matter. Careful blueprinting and attention to the right parts/right application will make this motor sing. 440's are strong, cheap and plentiful, plus with a bigger bore, it makes for a good stroker motor. The development just has been sort of unfair to the 413, other than the MAX-WEDGE technology.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: AndyF]
#62392
12/10/09 01:20 AM
12/10/09 01:20 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
The 413 has the same stroke as the 426 and the 440, it just has a tiny bore size. A 413 isn't going to make anymore torque than a 440 motor given the same camshaft, heads, intake etc.
I can't think of a single good reason to build a 413 motor other than the fact that a person wants one in order to be period correct.
Amen brother.
As for the 12 second 413 c body car's, I've never run into one myself. Unless we are talking 1/8th mile
[Re: AndyF]
#62393
12/10/09 01:25 AM
12/10/09 01:25 AM
HYPER8oSoNic
Desert Tracker
I beg to differ on the torque output of the 413. The 440 and 413 are fairly close, and you have to remember that the 413 was "pushing" more steel and iron than the 440 back then. The 440 was made because they needed a more tractable, larger mill than the 413. Which in turn lowered the torque rpm from 3400-3600 (413) to 3000-3400 (440). With the exception of the Long-Ram Inducted 413 which made it's torque at 2700-3000 (approx. 490-500 ft lbs worth). I would gladly take a good core 413 any day.
[Re: dave571]
#62396
12/10/09 01:36 AM
12/10/09 01:36 AM
HYPER8oSoNic
Desert Tracker
Venture out to an a Chrysler 300 (letter series) event and you will see a few of them. Most of the owners are trying to keep the dollar value on these cars at a high level. And I do not blame them one bit. Without the 413, you couldn't have the 426 or the 440. In the eighth, it would run quicker than high 12's. But I understand that this was before your time.
[Re: HYPER8oSoNic]
#62398
12/10/09 01:55 AM
12/10/09 01:55 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Nothing wrong with a 413, BUT the market has forgotten it. That said, I'm glad the letter cars exist, they were a milestone, and so was the model T ford, doesn't mean I want a T 4cylinder engine. Why pound on a dead horse? IF I could buy pistons for the 413 I have lying in my shop now I would have built it But I'm not going to invest $800+ into custom pistons and still net 30 cubes less then a 440 with $300 pistons, and have shrouded valves from the TINY bore I seriously tried for over a year to FIND pistons for the 413, no luck... It's now donating it's crank to a 446 build. Fire away
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: HYPER8oSoNic]
#62399
12/10/09 01:56 AM
12/10/09 01:56 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
How often can the 413 take that 62 over punch?
I've never seen one for sale at any price around here. I suppose I would run a good stock one until it needed a rebuild. No reason to waste stuff.
I want my fair share
[Re: Reggie]
#62402
12/10/09 02:25 AM
12/10/09 02:25 AM
HYPER8oSoNic
Desert Tracker
Gee, if the 413 was so great, it's a wonder that Ma Mopar just didn't keep that displacement and forget about the 426, 440. Not taking anything away from the 413 which was good for what it was at the time, but you just can't argue with more cubes. Besides, I think I'll listen to AndyF since he wrote the book....
Didn't Bob Dylan write a song called "These Times Are Changing". Technology caught up with the 413 and the "good intakes" could not fit under the newer hoodlines. Yes, displacement rules, but not in ALL cases. Power to weight must be balanced for a happy medium in performance. Still a great motor. Andy is good but Larry Shepard actually wrote the "manuscript".
[Re: HYPER8oSoNic]
#62404
12/10/09 02:37 AM
12/10/09 02:37 AM
R70RUNNER
Riverside, Ca
My thoughts exactly.
And mine... the block is getting bolted to a dolly and placed to sleep under the bench, maybe someday pistons will be available and she can regain her place between the fenders again
[Re: ScottSmith_Harms]
#62406
12/10/09 02:43 AM
12/10/09 02:43 AM
R70RUNNER
Riverside, Ca
I had my 1960 413 bored to 426 cubes ( I went custom forged but there are pistons available off the shelf for 426 bores), took it no problem and still had walls right around .200 thick on the thrust sides when done.
Scott,
You found 426 pistons with correct pin placement off the shelf that weren't 1000g cast rocks? EGGE has some but for the price..... Pass! I know Gbob had semi custom Ross build but still not cheap (383's with the pin moved.)
[Re: R70RUNNER]
#62407
12/10/09 02:46 AM
12/10/09 02:46 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
No I didn't, but then again, I never claimed to
Bottom line, you can buy standard bore 426 postons off the shelf. If what you find doesn't suit you it's time for customs. BTW, if the sonic checks out thick enough you can bore the 413 even more to get the next size 426 bore as well (426 + .030 etc.).
[Re: R70RUNNER]
#62408
12/10/09 02:48 AM
12/10/09 02:48 AM
HYPER8oSoNic
Desert Tracker
Thats why you don't need to get those 1500+ dollar eddy heads or victors. You can stroke a 413 and gain even more torque and have a great street motor. You can't just rev on it like a 340 or 383 because it isn't the same as one. Power is down low, so gear up the car accordingly to run well. Besides you made the first smart move to put the 413 crank into the 440. Chances are the original 440 crank was cast. Now make another smart move and put a 4.15" stroker arm in the 413. Costs just as much to stroke a 440, no excuses. Beat on a dead horse? Beat on this one and it will take you on a wild ride!
