Re: Need Help! Check Engine Light- Misfire on Cylinder 5 ? [Re: Blown69] #621588
02/26/10 12:11 AM
02/26/10 12:11 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
The magnum engines had issues with the intake gaskets (they would let oil into the intake port and cause detonation). There's a TSB out there for a flash, but it's just a timing retard flash. I would recommend changing the lower intake gaskets after exhausting all the other options (plug, injector, ignition)
Re: Need Help! Check Engine Light- Misfire on Cylinder 5 ? [Re: mopar155] #621589
02/26/10 09:40 AM
02/26/10 09:40 AM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I did plug wires on mine and about 4 months later had the same problem iirc #5 as well. Plug wire wnet bad and I had to buy a new set and just put the one on and solved my problem. My o2 sensor was bad as well.
