sealing up a oil pan with the right stuff #618518
02/20/10 08:16 AM
02/20/10 08:16 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i will be sealing up the oil pan soon and would like to try the right stuff without a gasket. do i need to use the end seals? does the sealant have to set up a bit before i torque the pan bolts? thanks
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618519
02/20/10 08:32 AM
02/20/10 08:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used Right Stuff on my pan before... you will
play HELL getting the pan off next time, I almost
destroyed my custom pan getting it off.... I used
the Right Stuff for the ends and rails.... I just
tightened it up so it was all flat then finished
tightening it up the next morning(about 2 turns)
Re: sealing up a oil pan with the right stuff [Re: MR_P_BODY] #618520
02/20/10 08:47 AM
02/20/10 08:47 AM
Mt Morris Michigan
Mt Morris Michigan
would ultra grey be a better choice of sealant? so just snug the bolts on fresh sealant and torque them next morning?
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618521
02/20/10 08:50 AM
02/20/10 08:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Now days I use the Mopar black RTV and tighten it so
its flat then torque the next morning.... I think the
ultra gray is like the Mopar RTV
Re: sealing up a oil pan with the right stuff [Re: MR_P_BODY] #618522
02/20/10 08:57 AM
02/20/10 08:57 AM
Mt Morris Michigan
Mt Morris Michigan
where do you buy the mopar rtv?
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618523
02/20/10 09:04 AM
02/20/10 09:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dealer... but I'm sure there is other stuff thats the
same.... I just happen to like it and used it for
many years at work
Re: sealing up a oil pan with the right stuff [Re: MR_P_BODY] #618524
02/20/10 09:16 AM
02/20/10 09:16 AM
Mt Morris Michigan
Mt Morris Michigan
ok, i might just try the ultra grey instead of the right stuff. dont want to ruin my new pan next time it comes off.
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618525
02/20/10 09:24 AM
02/20/10 09:24 AM
big mistake just using silicone. wait till you try to get the pan off. i think you are better off
cleaning the oil pan rail real good with brakeKleen use the right Stuff on the pan rail and lay your oil pan gasket on top of the right stuff. press and flaten and let sit overnight.
then clean block rail and put on the oil pan.
you wont be sorry doing it this way.
all silicone or the right stuff is a
Re: sealing up a oil pan with the right stuff #618526
02/20/10 09:46 AM
02/20/10 09:46 AM
Mt Morris Michigan
Mt Morris Michigan
i dont like the way the front seal and gaskets are pieced together. if i could get a one piece pan gasket for an LA 360 block that would be the answer to sealing this up. i'v always had pan or rear seal leaks and i want to get this right this time.
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618527
02/20/10 09:49 AM
02/20/10 09:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doesnt Mopar still make the 1 piece re-useable pan
gasket for the 360(silicone over a metal frame) I
dont have my books with me to look it up
Re: sealing up a oil pan with the right stuff [Re: MR_P_BODY] #618528
02/20/10 09:56 AM
02/20/10 09:56 AM
Mt Morris Michigan
Mt Morris Michigan
last i heard they had one for a magnum, but not an LA.
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618529
02/20/10 10:49 AM
02/20/10 10:49 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618530
02/20/10 11:01 AM
02/20/10 11:01 AM
Jefferson, OR
P
plumridiculous Offline
P
Jefferson, OR
The last gasket kit I bought had a one piece in it. my 360 is a '92 non magnum. I got it from northern auto parts web store.
George..
Re: sealing up a oil pan with the right stuff [Re: plumridiculous] #618531
02/20/10 11:09 AM
02/20/10 11:09 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I `ve always seemed to have an issue with rear main seals and pan gaskets leaking on my Crate 360 short block. Last week I went to my local Dodge dealer and bought a new rear main seal and one piece pan gasket and installed it with Right stuff. I`m putting the trans in this weekend so I can start it and check for leaks. We`ve always used Fel Pro gaskets with the pan rail and end gaskets being seperate, I like the Mopar one piece setup we`ll see how it holds up.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: sealing up a oil pan with the right stuff [Re: 11secdart] #618532
02/20/10 11:29 AM
02/20/10 11:29 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
use ultra black RTV (or something along those lines) in the caulk gun tube. toss the end seals in the garbage can also. i havent' used gaskets on oil pans and timing covers for years. and i agree with the above posts, don't use the right stuff its like cement in a can
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: sealing up a oil pan with the right stuff [Re: mopar dave] #618533
02/20/10 11:38 AM
02/20/10 11:38 AM
S.E. Michigan
cl440 Online content
cl440  Online Content
S.E. Michigan
We have used Ultra Black abd Ultra Grey. Both worked great! Haven't used an oil pan, timing chain cover or water pump gasket in years!
Re: sealing up a oil pan with the right stuff [Re: 68 HEMI GTS] #618534
02/20/10 11:44 AM
02/20/10 11:44 AM
PA
moparacer Offline
moparacer  Offline
PA
Especially if you use too much and it begins to break loose and plug up the pickup.
I used silicone last year between my windage tray and pan and tried to be careful not to overdo it and still had some sticking in the pickup when I tore it apart at the end of the year.
This year I am trying the fel pro rubber coated gaskets and glued them on with copper coat prior to installing them.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: sealing up a oil pan with the right stuff [Re: moparacer] #618535
02/20/10 11:48 AM
02/20/10 11:48 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I've had good luck with the Right Stuff on the oil pan, doesn't come off easy but it's not that hard to get it off, just drive in a thin scrapper and slice the pan off? Be tough thou if you were dropping the pan in the car.
Re: sealing up a oil pan with the right stuff [Re: wyoming] #618536
02/20/10 12:22 PM
02/20/10 12:22 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Right Stuff works great, but you'll need dynamite and hand granades to get the pan off. This time around I'm going to use Hylomar blue on everything except the intake end rails. Hylomar doesn't harden but it does make a nice self healing seal.
Re: sealing up a oil pan with the right stuff [Re: torkrules] #618537
02/20/10 09:08 PM
02/20/10 09:08 PM
Mt Morris Michigan
Mt Morris Michigan
i searched northern auto web site for the one piece gasket and found nothing. i'll have to call them monday.
