Disc brake conversion hose routing #61837
05/22/08 10:54 PM
05/22/08 10:54 PM
southern Idaho
moparcyco Offline OP
southern Idaho
I'm right in the middle of putting disc brakes on my bee with the factory 11.75 rotor set up with sliding calipers.But it looks like the sway bar won't clear the calipers unless I flip them to the rear.My question is if you do this what hoses should you use?I thought I read a post a while back on this but can't seem to find it.Any links or info from someone who has this setup would be a lot of help.
Re: Disc brake conversion hose routing [Re: moparcyco] #61838
05/22/08 11:04 PM
05/22/08 11:04 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
76/77 Aspen/Volare They are just a little longer than they need to be, so check them lock to lock for clearance.
NMCA NSS 67 Coronet
