Valve cover baffles. #61606
05/22/08 01:02 PM
05/22/08 01:02 PM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
So after waiting over 2 weeks to get baffles, I still dont have them and have resorted to making
my own. They are fab'd up now but the question is
do they go bent up towards the intake or bend down?
They look like the MT ones with a lazy z so to speak.
Re: Valve cover baffles. [Re: Dart 340] #61607
05/22/08 01:55 PM
05/22/08 01:55 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
They should be flat except for the ends.
They should be bend down toward the head.
That way any oil will drain back down.
It's not a lot of bend just enough for the oil to run off.
Re: Valve cover baffles. [Re: cyphre666] #61608
05/22/08 02:00 PM
05/22/08 02:00 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
The Holley / Mickey's accessory part has one up and one down. I would assume the higher point is up and the lower side goes down to help oil drain, would that be right?
