2004 DODGE HEMI CHECK ENGINE LIGHT #61603
05/22/08 01:01 PM
05/22/08 01:01 PM
Anonymous OP
Anonymous OP
I HAVE A DODGE 3500 WITH A HEMI AND THE CHECK ENGINE LIGHT COMES ON SOMETIMES WHEN I GET LOW ON FUEL. IT WILL GO BACK OFF AFTER I FUEL UP. DOES ANYONE KNOW WHAT IS GOING ON.
Re: 2004 DODGE HEMI CHECK ENGINE LIGHT #61604
05/22/08 01:10 PM
05/22/08 01:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Turn the key off and on 3 times, and read the P code from the message center in the IP.
Re: 2004 DODGE HEMI CHECK ENGINE LIGHT #61605
05/22/08 03:05 PM
05/22/08 03:05 PM
michigan
black64 Offline
black64  Offline
michigan
The vehicle does a vapor recovery check when first started sometimes a loose gas cap or a slight leak in a hose at the filler neck will turn the light on.
