Re: Blow by of oil out of breather
[Re: mopars4ever]
#61559
05/22/08 08:40 PM
05/22/08 08:40 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I have friend with a very solid 383 with minimal miles that started doing that. He hasn't looked into it yet. I just wonder if there is a problem with rings seating in rebuilt engines that sit a lot? There also has to be an influence from high compression pistons as well.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: dfsmopars]
#61560
05/22/08 10:13 PM
05/22/08 10:13 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
anything unusual out the tailpipes???
My 340 GTS blew a head gasket up into the lifter valley once years ago. Blew smoke out one tail pipe (no H pipe), and puffed smoke out the oil fill/breather like a locomotive (puff puff puff)as well. Engine was fine, just the blown head gasket (no coolant leaks in this case).
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: mopars4ever]
#61562
05/23/08 01:50 AM
05/23/08 01:50 AM
Posts: 13,572 md
mopars4ever
md
If you are using a street type exhaust you will end up pressuring your crankcase instead of evacuation it
Would it work with a one way diverter type valve? I have 3 inch exhaust and turndowns before the axles. Would that make any difference in getting it to work? Mike
[Re: mopars4ever]
#61563
05/23/08 01:52 AM
05/23/08 01:52 AM
Posts: 13,572 md
mopars4ever
md
I agree with Bob that you may have a ring seal problem, If thats the case it will only get worse. I had the same problem last summer.
I`m sure there is a ring seal problem but I like to use the car some this summer before the rebuild. Mike
[Re: mopars4ever]
#61565
05/23/08 09:25 AM
05/23/08 09:25 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
Use some old socks to wrao the breathers when you leave the house and enjoy the summer, when winter comes tear it down. Thats the route I took.
