833 lube #61543
05/22/08 11:20 AM
05/22/08 11:20 AM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Whats a good weight lube to run in a tired 833?
is 80/90 or 80/140 better? Same for the 8-3/4 rear?
Is 80/140 too heavy?
Re: 833 lube [Re: Dart 340] #61544
05/22/08 11:47 AM
05/22/08 11:47 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
contact jamie passon for a lube he sells , or get castrol syntorq
Re: 833 lube [Re: Dart 340] #61545
05/22/08 12:08 PM
05/22/08 12:08 PM
Kirkland, Washington
Pacnorthcuda Offline
You want a GL-4 in the tranny (I use a 75-90) and a GL-5 (extreme pressure) in the rear. Redline makes some great products for both.
Re: 833 lube [Re: Pacnorthcuda] #61546
05/22/08 12:16 PM
05/22/08 12:16 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
How about Valvolines race 80/90 I can find that on
the shelf here.
Live in Ford nightmare hell land.......
Re: 833 lube [Re: JohnRR] #61547
05/22/08 03:46 PM
05/22/08 03:46 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Great stuff and excellent people to deal with!
Re: 833 lube [Re: Dart 340] #61548
05/22/08 03:58 PM
05/22/08 03:58 PM
the shelf here.
I'd be willing to bet the Valvoline 80/90 is a GL-5 Hypoid gear lube. Designed for rear-end (ring and pinion) use. Fine for the rear, not so fine for the 833. Find a GL-4 for that.
Re: 833 lube [Re: Dart 340] #61549
05/22/08 10:45 PM
05/22/08 10:45 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
What? No Dexron?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 833 lube [Re: Rug_Trucker] #61550
05/22/08 11:48 PM
05/22/08 11:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What? No Dexron?
